New flat fan kit installed
Hi all finally have the new flat fan kit installed man what a job... lots of machining, fabricating and modifying parts to fit. Also made few other changes... waiting on an alternator belt then back on the dyno will post more pics as I progress..
Old 02-13-2019, 01:29 AM
flat fan
more pictures
Old 02-13-2019, 01:33 AM
Undutched's Avatar
That thing is nuts. What Impeller are you using? 245mm or 279mm? How much air will this move?
How much power will this take 30HP or so at top end?
Old 02-13-2019, 02:04 AM
Mike Billings's Avatar
I like the intakes. Four inch square aluminum tubes?
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R6 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 3+
Old 02-13-2019, 05:24 AM
the fan is powered with an electric motor so the power draw is not linearly connected to the RPM's of the engine like a belt driving one. I highly doubt it takes more than a few ponies to power it, way less than a belt one.
Old 02-13-2019, 05:55 AM
what a engine porn , very nice.
Old 02-13-2019, 09:43 AM
full quack's Avatar
Send a message via Yahoo to full quack
As far as I can ascertain, that particular kit's fan is most definitely NOT powered by an electric motor, it is shaft driven, just like the original 935 design.
Can't get over the thickness of the front mount plate and the huge size of the alternator adjustment rod....way over kill...but that's not necessarily a bad thing.
Mark
Old 02-13-2019, 10:12 AM
speednme1's Avatar
Wow! Very nice!!
Rey....77 930 "the Mistress"
Old 02-13-2019, 10:18 AM
Flat fan
Thanks for the encouraging words.. anyone who has attempted anything like this will know the extreme difficulty and cost to get it right... The fan drive is driven of the crank as the factory 935s... the front idler mount had to be that thickness as nothing lined up as quoted.. further machining of parts and fabricating spacers has got me to this point ... weighing up the cost of this kit including all the mods carried out i would have been better of buying a complete factory 935 kit even though they are around 25-30K USD if you can find one...
Also fitted 075mm turbo oil fee line restrictors down from 1mm as i was getting oil in the intercoolers and plenum also fitted heatsoak spacers under the individual throttle bodies..
Well i hope the combination works as i am not chasing outright mega HP just wanted something different
Old 02-13-2019, 01:38 PM
Other than cool factor, what does it buy you in the end?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 02-13-2019, 01:56 PM
Turbo Powered Snow Blower
Being different. That is the basis behind 90% of custom car builds.
If you have the means then why not.
Derrick
Old 02-13-2019, 02:51 PM
Flat fans also provide more even cooling across all cylinders unlike our 911/930 upright fans.
Rahl
Old 02-13-2019, 07:39 PM
Yup, our pedestrian upright fans have pretty uneven cooling. At least from what Iíve read. To bad there were so many installation/financial hurdles.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-13-2019, 11:08 PM
Something like this is always annoying, of course
Old 02-14-2019, 05:32 AM
Old 02-14-2019, 10:42 AM
Tug68's Avatar
Awesome!
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 02-15-2019, 07:38 AM
petri's Avatar
Very much like that, indeed! . Awesome!
Garage: Strosek 911 RUF BTR|Strosek 911 3.6 rat RSR|Strosek 928SR|928S4R|928S|996C2RSR...and more... Altogether 11 Germans - 3 Italians - 2 British
Old 02-15-2019, 10:50 AM
Holy moly!! I am humbled...hat in hand as I bow.
Old 02-16-2019, 05:07 AM
Large Member
krasuskyp's Avatar
that is batshiitcrazy bonkers - nicely done, keep up the amazing work
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 02-16-2019, 07:56 AM
VZ935's Avatar
Send a message via AIM to VZ935
Very cool! Hopefully will have some factory replica flat fan set ups later this year. Here is my 962 fan stripped down after being taken off the 3.4 RSR engine for those that would like to see some details of the drive unit
A bunch of old race cars
Old 02-17-2019, 08:21 AM
