GSF Fuel Rail - O Ring Size
Hi Guys
I recently purchased some new injectors from Five-O Injectors. They are 14mm Injectors
What size O rings should I get for the fuel rails. 15mm GM (Red) O rings or stick with the 14.5mm (Blue) Bosch. I am running the extender caps.
Thanks in advance
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 03-13-2019, 06:58 PM
Ended up sticking with blue 14.5mm, working well.
Old 03-22-2019, 04:08 AM
