How is this oil line routing?
I didn't like the fit of the stock hard line from the case around to the 2-part line from the thermostat so I fabbed this up from -12AN racing hose and some fittings. I'm not 100% convinced on the routing but its the best I could come up with. Its sort of an important line being that a break would dump all my engine oil in moments.
Its an aluminum oil line to -12AN adapter in the case (actually for oil coolers), -12AN 90 degree elbow, -12AN racing hose rated to continuous 300f and 1,000 psi, and another -12AN to 30mm adapter at the other end (yes, I know its not tightened down in the pic).
I've got it in a WG16 Adel clamp so its not going to flop around at all. However, it does cross and rest on the exhaust as you can see. It crosses as close to 90 degrees as I could make it, and doesn't run parallel to the exhaust anywhere so it as as little proximity to the exhaust as possible. But short of running it around the front of the engine there's nothing better I can do.
It does also rise then dip back down a little as it wraps around the heater hose, but running it inside the heater hose would have caused interference with the lower valve cover.
Thoughts? Is this an acceptable installation?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition, and EBC. SC cams, K-27/29, Tial 0.8bar, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 03-24-2019, 12:41 PM
Alan L's Avatar
Why don't you follow the original route?
I would be concerned about that hose being against the headers. 300 degF is bugger all compared to the 1500 deg F you get on the headers.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-24-2019, 03:28 PM
Alan
The original route is under the headers, and there was damage to the line from ground contact or something. Also the hard line runs parallel to the headers for at least 6-8" around the rear of the motor. Also I had to jigger around the exhaust and just couldn't get it to fit correctly.
Old 03-24-2019, 03:55 PM
Alan L's Avatar
my hard line tracks foward and over the bellhousing area. Away from the headers. I am sure it is stock. My SC is same. Have the 930 on hoist at moment. Would take a pic, but no camera right now.
Alan
Old 03-24-2019, 04:14 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Yo FL, it there room there to attach a hose clamp, or similar, to the headpipe and then make a small standoff for the oil line?
If not, maybe you could use a piece of high temp tubing sleeve over the hose, in the area where it's mading contact with the headpipe.
You really don't want that oil hose in direct contact with the pipe - could possibly coke any oil, or oil film, that's in it after shutdown . . . even as little as a couple millimeter air gap would be sufficient (or insulated from contact if no air gap is possible).
Old 03-24-2019, 05:02 PM
Alan L's Avatar
Just to confirm the route of my solid tube - from the crankcase pick up it goes fowards and wraps around under the bellhousing. Not the best pic - taken for the clutch assembly, but tube is at very top of pic.
regards
Alan
Old 03-24-2019, 06:51 PM
Porsche changed that in the mid 1980s (at least for Turbos) to a hard oil pipe that runs along the back, bottom side of the engine and then connects to the oil hose seen in FL's last pic.
Old 03-24-2019, 07:56 PM
I have enough hose to fab up another if I need to. I'll have another go at it this weekend.
Old 03-25-2019, 04:55 AM
Absent an alternate choice for routing, I think I'll make a curve piece of mild steel with some "legs" and simply hose clamp it to the exhaust there to give myself maybe 1/4" or so airgap.
Old 03-25-2019, 10:00 AM
Alan L's Avatar
Given the critical nature of that hose, I would be somewhat nervous about having a flexi hose so close to the headers. For peace of mind is there any way it will route the alternate way?
Alan
Old 03-25-2019, 10:32 AM
Alan
You mean around the front of the engine? Not and easily mate up with the line from the thermostat. I'd have to fab up the entire run. I'll look at it, but not sure how viable that is.
The stock hard line runs across the headers and also runs parallel to them much more than this line, and the hard line will conduct heat to the oil much more. However the braided steel over rubber line itself is more susceptible to heat.
Old 03-25-2019, 10:41 AM
Alan L's Avatar
yes, it is not so much the heat in the oil I am thinking of. My catch can for the turbo is very close to my headers.
But I am thinking of the heat accumulation on the flexi hose. Having it in such close proximity to 1500 def F constant heat. It must soak a lot of that heat up. The oil may heat up somewhat, but the heat has to have been conducted thru the flexi tubing first, to do that. And that is the bit I would be concerned about. A single event may not be the issue either, but the constant heat stressing of the rubber internals would be my worry - fracturing etc.
Bear in mind the oil is already around 200 deg F, so you only have 100 deg F headroom with the hose right against the headers. It must be at or beyond its continuous rating.
Regards
Alan
Old 03-25-2019, 11:11 AM
I went forward and over the top of the transmission. To stay as from the heat as possible and in all of the dirt you will see my heat wrapping .... looks like I should clean things and redo that wrapping. Has worked well for 4 track seasons - I guess that explains the dirt.
Cheers,
Dave
Old 03-25-2019, 12:00 PM
With headers the solution was to use a 74 crossover, great fit.
ER has one runs over the top as well.
https://www.elephantracing.com/porsche/911/oil-cooling-for-911/oil-lines-hoses/
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 03-25-2019, 12:46 PM
Is the fitting size on the thermostat the 30x1.5mm convex fitting?
Old 03-27-2019, 09:53 AM
$50 for an original under the bell housing line.
https://www.partsheaven.com/Porsche_used_75_77_911_Oil_Pipe_For_California_Car _p/91110774410.htm
Old 03-29-2019, 04:08 AM
TurboKraft's Avatar
Cheers,
Dave
This.
Or use OEM pipes:
911 107 739 10= Oil Crossover Pipe, from Engine, 1973-74
930 107 729 10 = Oil Line, Oil Crossover Pipe to External Thermostat, 1973-74
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-11-2019, 01:53 PM
I essentially replicated that routing as I had line and fittings on hand. Thanks
Old 04-12-2019, 03:54 AM
