-   -   Rear tire size alternative ... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1025180-rear-tire-size-alternative.html)
ertech 03-30-2019 03:45 PM
Any other size then 245-45-16 is good for the rear on 89 930 on stock wheels
gumba 03-31-2019 08:34 AM
Unfortunately there isn't anything wider in a street tire available.
sunlion 03-31-2019 03:09 PM
255 50 16 BFG G Force Sport Comp 2 on 16x9 rears fuchs, with a 1” spacer.
Geronimo 04-01-2019 03:12 PM
245 seems very narrow for a turbo, I'm running 245's on my SC.
gumba 04-01-2019 05:15 PM
245 was the stock size. The 255/50/16 mentioned above is 1.5” taller (26.1” vs 24.6”) and about .750” wider than the 245/45/16. A good size would be 275/40/16, wishful thinking.
356911930 04-01-2019 05:47 PM
What about the Michelin TB tires?
Rahl
gumba 04-01-2019 06:14 PM
Only available in 15’s.
sunlion 04-05-2019 08:42 AM
Is there a Fuchs wheel with the correct offset for a 275/40/16 tire......that would be a perfect wide load for the rear of 930....no spacer needed!!
gumba 04-05-2019 08:52 AM
Unfortunately there is no 275/40/16.
Capt Bob 04-05-2019 04:12 PM
I'm running 17's -
255/40/17 on the rear
sunlion 04-06-2019 10:04 AM
http://forums.pelicanparts.com/uploa...1554573827.jpg
