Hose location??
Hello Folks.
I am putting back together my 930 engine from a very detailed cleaning.. and cannot remember where the other end of this hose hooks to back up to?? Anyone know off the top of their head? thx. ![]() |
Mighty Meatlocker Turbo
That connects to spout on the endcap (firewall side) of the recirculation valve housing (left side of the secondary intake manifold).
Great thanks
THis Bit? ![]() |
Yep. It's somewhat tricky getting the hose connected, but doable.
Indeed.....
Broke the hose,, it was very brittle.. I will need a new one .. Anyone have softer one? Dealer or Pelican? After part diagram search ... there is no part number for this hose.. thanks! ![]() Last edited by 991gts6s; 05-07-2019 at 03:22 PM.. |
When I replaced mine, I bought an appropriately sized length of hose from an auto parts store (nothing special about that hose - just needs to be sturdy, and the cloth covering is of no benefit, unless you are looking to visually replicate the original), and then inserted a suitably sized spring into it (in the area where the bend is made) so that the hose would not kink where it curves fairly tightly. That is a way you can work around needing to use a pre-formed hose.
Rey....77 930 "the Mistress" |
I was able to find the correct part number OK for the bulk hose in the parts fiche - the actual hose part number refers to a cut length from the main hose.
Seeing as I could not find the correct hose from our host when I was looking, I think it will be OK to point you to : Parts Kl@ssik SKU # 2620.1300 I had to replace the exact same hose on my '78 930 and it very much matched the original hose. I'd sent you the rest of the 1metre purchase I had left over but shipping from New Zealand would be more than the hose :-( |
