930 Tach in 911SC
Hi guys, I've acquired the majority of the parts to do a turbo conversion to my 1983 911SC.
I would like to add an AFR gauge and obviously a boost gauge as well, but would like to keep everything in the 5 pods in the dash. Is there any way I can wire a 930 tach into my SC, assuming I use a factory boost sensor on the IC (going with a Koklen and doing away with 930 bypass system)? It looks like the SC tach has three inputs and the 930 tach has four. Is it really just a matter of running a wire from the sensor to the extra blade terminal on the tach? Thanks in advance! |
I have a 930 tach into my '77, they share the same connections and its working fine. the 4th terminal is for the boost gauge.
