-   -   Intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1031470-intercooler.html)
HIpsi 06-05-2019 11:34 PM
Intercooler
Hello gentlemen What is the recommendation in aftermarket Intercoolers.as I am starting to turbo my 3.2 and want to keep the air conditioning.http://forums.pelicanparts.com/uploa...1559806381.jpg
ljpviper 06-06-2019 03:08 AM
Sorry just noticed you have a 3.2 that your converting to turbo. Not sure then disregard my advise.
I am also looking to purchase an intercooler. Just picked up an 89 coupe a few months back.
The Fabspeed kit looks well put together and claim some nice gains in hp and torque. I put on their supercup muffler and am real happy with it.
Let's here what others recommend.
Larry
Edelweiss 06-06-2019 04:30 AM
Contact Chris from Turbokraft - he is your man !
kamaro 06-06-2019 07:21 AM
I'm in the same boat. My plan is to buy a full size IC which is meant for Mitsubishi Evo and have it modified, then I'll just try to put a single larger condenser in the front with a couple of 8 in. cooling fans.
dos531 06-06-2019 08:43 AM
Talk to turbokraft, they will make something to your specifications.
scottrx7tt 06-06-2019 10:56 AM
My evoX intercooler set up.http://forums.pelicanparts.com/uploa...1559847328.jpg
HIpsi 06-06-2019 09:01 PM
I want something looks like modified standard Square like RUF but cost less �� my Objective is show car with Corrector turbo set up and the most important is the sound of the west gets witch I am planning to install 2
s5uewf 06-13-2019 04:07 AM
I have a half bay B&B in a cabinet in storage. I upgraded to a Turbokraft a few years back. Willing to part with the B&B at a reasonable price.
crb07 06-13-2019 08:19 AM
http://forums.pelicanparts.com/uploa...1560442673.jpg
Turbokraft
cmcfaul 06-13-2019 12:13 PM
Cbr07......sweeeeet!!!!
JMS935 06-13-2019 12:18 PM
Originally Posted by crb07 (Post 10490412)
Thereís no need for driving your SUV with a mobile grill tucked in the back to the barbecue when youíve got a full size built in grill under your tea tray! :eek:
crb07 06-13-2019 01:16 PM
I have a TurboKraft half bay on my 89. It is nice.
kamaro 06-13-2019 03:21 PM
Originally Posted by scottrx7tt (Post 10482680)
Looks good!, do you have your A/C working? what is your condenser setup?
robosst 06-13-2019 03:32 PM
scottrx7tt, what's supporting the intercooler from the back?
I've got an evo intercooler i still need to modify.
scottrx7tt 06-13-2019 04:38 PM
Yes A/C working. I fabbed up some 993 condensers. 1 in the front wheel well., another in the rear. Have a rennaire upgraded front condenser also a pro cooler. Currently getting temps in the 40s. Still not completely happy with my A/C set up, but want to believe itís slightly better than original factory set up.
scottrx7tt 06-13-2019 04:48 PM
The guy that modified the inlet location welded on some mounting nipples on the back of the intercooler. Just like the ones on the front. I was able to bend some flat aluminum bar stock from Home Depot from the back mounting Nipples down to some threaded holes in the Carrera intake. It is actually feels pretty strong, but I plan to pretty them up a little one day http://forums.pelicanparts.com/uploa...1560473240.jpg
Shrapnel 06-13-2019 07:13 PM
Searching for similar as this set up i have is out dated and the mounting brackets are home made.
Any info here about this machine or AMAG built 85 930 Slant nose? Iíve been searching...http://forums.pelicanparts.com/uploa...1560481620.jpghttp://forums.pelicanparts.com/uploa...1560481927.jpg
Geronimo 06-14-2019 07:25 AM
CRB07 What wing are you running? That thing is a work of ART!
crb07 06-14-2019 08:08 AM
Stock wing.
TurboKraft 06-14-2019 01:56 PM
Thank you! That's our Billet Full-Width Intercooler, starting at $4200.
Here's our two smaller intercoolers that work with the 3.2L Carrera manifold:
TK Full-width Intercooler
Starting at $3100, bolt on with inlet & outlet charge pipes, manifold mounts
http://forums.pelicanparts.com/uploa...1560547642.JPG
Half-bay Intercooler -- can keep original 930 A/C condenser in the wing
TK Starting at $2500, bolt on with inlet & outlet charge pipes, manifold mounts
http://forums.pelicanparts.com/uploa...1560549211.JPG
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
