gumba's Avatar
strange a/f ratios
Everything has been running fine until recently. A few weeks back I noticed the motor went way rich, 9.5-10:1 under acceleration (1/2 throttle) getting on the freeway. When I backed off it would go back down to 12-12.5 at cruising speeds. Recently, after the motor warms up, at idle the motor goes way lean, 16:1. When I start driving it goes back down to 12-13:1. It's not the gauge/sender because the motor is reacting to both conditions.
WUR pressure is 38 psi when warm.
This is a modified 3.3 motor, cis, wur, Electromotive xdi single plug. I have another WUR I can swap in but thought I'd check here first.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 07-01-2019, 03:17 PM
T77911S's Avatar
you have an air leak on the pressure side.
the turbo blows air OUT requiring more air in thru the AFM making it run richer
then sucks air in at idle making it lean
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 07-02-2019, 02:46 AM
gumba's Avatar
That was it.
Harold
'79 930/DP935
Old 07-03-2019, 03:46 PM
