Alan L's Avatar
Euro CIS fuel lines
Anybody got some F/S? Any idea of prices - tossing up whether to Fab some up. Presume they run on the same port/FD fittings?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-11-2019, 12:20 AM
There's a pelican member (Len) that makes them. I picked up a full set for mine believe they were $350. picture of the lines in my build below. I'll have to dig through old PM's to find his handle here on pelican. Maybe someone will know if off the top of their heads.
It's about time.. Finally have a 79 930 :)
'79 930 turbo RoW - Oak Green Metallic - k27-7200 - Kokeln Intercooler - RarlyL8 headers/muffler - Leask WuR - Tial 46mm - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10
'99 4Runner Sr5
Old 07-11-2019, 09:45 AM
BoxsterGT is his pelican handle. He uses cohline fuel hose and the fitting all said made in Germany if I'm remembering correctly. They are high quality.
'99 4Runner Sr5
Old 07-11-2019, 09:50 AM
Alan L's Avatar
Thanks Jacobs 911 - am following a lead right now for 2nd hand. Thanks for the option.
Regards
Alan
Old 07-11-2019, 12:35 PM
patkeefe's Avatar
I think Len retired, but you will have to ask him for confirmation. You can also ask Mason_paul.
Patrick E. Keefe
78 SC
Old 07-13-2019, 05:48 PM
Alan L's Avatar
Thanks Pat.
I am sorted - on the way, via a fellow Pelican.
Regards
Alan
Old 07-13-2019, 06:08 PM
BoxsterGT's Avatar
Porsche Crest
Good day or evening fellow Pelicans depending on where you all are presently.
Alan, correct me if I am wrong, but I think you might have a US model 930 with small diameter steel injector lines and want the larger ones of the ROW model that flow more fuel. Also, the fittings are different between versions.
These should be available as take-offs, as many owners have gone to EFI for additional performance.
If for any reason you or anyone has 930 or 911SC CIS lines that have Rubber or Polyamide content and need them Re-Made I can help. However, I cannot help with the steel injector lines.
Len.Cummings at verizon.net
Old 07-13-2019, 06:10 PM
Alan L's Avatar
Yes Len - correct - US version fuel head. Small diameter fuel injector lines. Have some larger ones (Euro) on the way. Hopefully they fit?
Regards
Alan
Old 07-13-2019, 06:29 PM
T77911S's Avatar
did you find some
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 07-23-2019, 06:02 AM
Alan L's Avatar
Yes, some have arrived. Fellow Pelican.. again.
Alan
Old 07-23-2019, 06:49 PM
