Cylinder wall damage at top, in ring area
All,
While inspecting a newly rebuilt engine for purchase I discovered, using a Snap-On BK5600-OD bore scope, what appears to be a chipped damaged area in the very top section of a cylinder. The damage appears to be just below the top ring area of the piston at TDC and just above the top of the oil ring. The bottom of the photos, the silver area, is the squish band area of the cylinder head near the intake valve. Based on the photos below can anyone tell me how much of a risk do I have that the cylinder or piston rings will prematurely fail? The engine has not been run, does not even been filled with oil but is fully assembled and ready to be installed into the car.
Just hoping to receive some wise counsel from the engine experts on Pelican. I also posted this in the Engine Rebuilding Forum but thought the TURBO guys my have some unique insight on this situation considering the combustion temps and thermal expansions they experience in their engines.
Old 10-12-2019, 08:58 AM
Its hard to tell, but are you sure its actually damage in the surface of the cylinder wall and not simply a piece of debris that is stuck there?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 10-12-2019, 11:38 AM
If it is indeed damage to the cylinder wall in a location where one of the rings passes over it
I would be concerned
Tony
Old 10-12-2019, 04:57 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Nikasil is HARD!!!!! to say the least. It looks like something sharp fell right in and on the cylinder wall. It definitely happened during the build. The damage is too bright to have been done prior. Pull that bank apart and just that head to pull the sleeve and have it replated. The general rule is anything less than .004 will be OK. Unfortunately that looks more than .004
It changes from time to time.....
Old 10-12-2019, 06:06 PM
