Ignition Key Code 930
I have only (1) key for my 930 and I need to get a replacement key cut before I loose the one I have.
See attached photo of the key code for my 930. Anyone know who I can get a key cut? Bobhttp://forums.pelicanparts.com/uploa...1563560046.jpg |
I am not in the US, but in New Zealand I have had keys cut no problem - just by the regular guys you find cutting house keys in the mall or where ever.
The trick is to find a key cutter who has a Porsche blank - that may take a bit of hunting. If you find that you will find the guy to cut the key. he doesn't need/won't use the code. He will use your old one as the template. They can cut any profile - as long as they have the blank. the code is only useful if you loose the last key. That renders the lock useless - unless you have the code. Regards Alan |
you can buy the blanks here and take them and have them cut almost anywhere. Also if you need an alarm key for the door it's a 944 ignition blank.
Thanks - I do have one key remaining so now to purchase a blank.
| All times are GMT -8. The time now is 03:50 AM. |
