Twin turbo cylinder heads
Hi all just want to know what are the ultimate cylinder heads for high horsepower...valve sizes, port sizes, ect .. I had my engine rebuilt but my heads are not up to it ..so should I just buy a decent set of heads or modify mine. seen the billet heads has anyone had success with these..... looking at the 650-700HP range current engine specs are 3.4 litre Pauter rods Gt3 oil pump 993SS cams Individual throttle bodies Autronics ECU Flat fan twin Garrett turbos...
Old 07-20-2019, 05:00 PM
Mike Billings's Avatar
It's not easy to beat these:
https://www.xtremecylinderheads.com
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R6 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 3+
Old 07-20-2019, 08:42 PM
kevinbodman930's Avatar
Call Turbokraft and they can set you up.
Old 07-21-2019, 01:20 AM
Pat Williams Racing build a twin turbo 3.4L 700hp @ wheels with "only" ported twin plug heads and STOCK valve size 49mm as far as I know. 1 bar of boost. Nice car, and some 10 years ago. Properly used race gas, but E85 should be close enough today. And it used 4 gear 930 transmission btw. It won several races - see videos
Compared to your wishes and specs, it is quit similar but this one is using regular fan - see last link web for build pictures and descriptions
https://www.youtube.com/watch?v=HlF8x-EaBTs&t
https://www.youtube.com/watch?v=xsr8jg9pSds
https://www.youtube.com/watch?v=f62wtlzu728
Pat Williams Racing (porsche)- 3.4 litre twin turbo race car
Old 07-21-2019, 05:06 AM
I would rather be driving
jpnovak's Avatar
What do you have for your induction port sizes? Include runner diameter and port diameter?
If they are stock 930 heads with small ports they may be choking off flow. There are a few options.
-open the intake and exhaust ports on your 930 heads. A plunge cut on a mill is usually the best way.
-switch to 3.2 Carrera heads. You must have enough intake flow to take advantage of this.
- have Extreme or other place CNC port your heads. This will optimize flow and more importantly intake gas velocity.
Not sure what you currently have so I can not make more detailed recommendations.
It comes down to cams, peak torque RPM. Peak HP rpm. Flow rates at these 2 rpms. Boost level etc. It all has to work together and be optimized as a package.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 07-21-2019, 10:01 AM
