AskewRSR's Avatar
76 930 with Lim Slip 915 Trans Clutch and Flywheel options??
What Clutch and Flywheel would you use on this set up. It needs a 6 bolt flywheel.
What clutch set up? Part numbers would be great. Let me know. Thanks. T
1967 911 S Bahama Yellow
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 07-22-2019, 09:27 AM
stevie 77 930's Avatar
76 3.0 turbo flywheel
1983 911SC
1974 914
2018 GTS
2017 BMW 340I M Sport Package
'76 911s , '72 911t, '73 1/2 911t, '77 Turbo (all gone)
Old 07-22-2019, 09:31 AM
AskewRSR's Avatar
Thanks. I saw Eric already posted. Much appreciated. T
Old 07-22-2019, 10:52 AM
Uncertifiable!!!
Uwon's Avatar
Tried Kennedy Clutches?
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 07-23-2019, 03:30 AM
911tracker85's Avatar
I have a clutch kit I took out of my 78 930 conversion that still had a 915.
finally found a short bell housing 930 gearbox I plan to use. have not checked to see if my clutch will work on that or not.
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
87 924S resurrect and gut and another track car...
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 07-23-2019, 05:53 AM
onboost's Avatar
It won't work, different stack. 78 930 conversion.. if 3.3 is different crank than early 3.0 930. Early 3.0 based on 6 bolt 2.7 crank and clutch pack is different.
RGruppe #180
Old 07-23-2019, 06:18 AM
Brando
quattrorunner's Avatar
Just get a 6 bolt 225 flywheel and a strong sachs kit like the SPORT aluminum setup. It'll hold 300hp/325tq fine.
Here's a good one
WVO STRTLT 915 6, WVO-STRTLT-915-6, WVO.STRTLT.915.6, WVOSTRTLT9156
Turbo powa!
1977 911s. it's cool
Old 07-23-2019, 09:08 AM
Brando
Also if you're wanting a bit more boost/power then try the centerforce 225 unit, not aluminum but it's strong and not expensive.
Turbo powa!
Old 07-23-2019, 09:21 AM
915 Power Clutch is a stock clutch, cherry-picked at top 10% of spec. They're a little marginal with a 3.3 - as in right on the edge of what they'll hold. As little as SC cams and an open muffler might tip you over the edge. Or, in other words, don't expect a long life - I was seeing friction plates were down to the rivets after 12, 15000 miles. Seems likely it was slipping - although it didn't seem to be when driving the car...
Is a Sport PP actually more clamping power, or just less rotating mass at the same spec? I had the impression it was the latter, but it's so long since I pored over the specs trying to find something to work, I forget...
Find someone who knows, or find the specs and order the appropriate parts; There is a 915 pressure plate marked "ZF Sachs Race Engineering" that'll comfortably hold well over 400FWHP - my shop said it was the closest thing to an RSR clutch they can still get. But its a PITA, you don't want to resort to that unless you have to - and overkill for a 3.0 930 in stock-ish trim.
But they also do multiple options in-between, depending on what you need.
An important thing to bear is mind when comparison shopping is that specs from Sachs apparently have a safety margin of about 20% baked-in - as in, if Sachs quote 300 ft/lbs, everybody concerned would be pretty surprised if it let go before 360 ft/lbs or so.
Aftermarket clutches usually do not - or so I've been told (I only ever used Sachs parts). As in, if they quote 300 ft/bs, it might let go at 301.
'77 S with '78 930 power and a few other things.
Old 07-23-2019, 11:51 AM
Brando
I’ve had so many clutch combos with that engine trans combo that I feel like I have some experience. Yes the power clutch slips while not really feeling like it’s slipping. it does wear out with .8bar boost. The centerforce did hold better. Enough to break the second gears of two 915 transmissions.
The stock 930 clutch doesn’t hold much better than the 225mm power clutch. It let’s go more obviously.
I didn’t try the 225mm sport clutch because it’s expensive. The power clutch is aluminum though.
Turbo powa!
Old 07-23-2019, 12:15 PM
Iíve had so many clutch combos with that engine trans combo that I feel like I have some experience.
Heh. I know that feeling... Went through 4 clutches in quick succession (with the emphasis on "suck") in a few months.
I didnít try the 225mm sport clutch because itís expensive. The power clutch is aluminum though.
Pretty sure I tried a Sport at one point, with some fancy lining on the friction plate. Another for the pile of discards.
This worked for me, but wasn't all sunshine and puppies:
Old 07-23-2019, 04:37 PM
Brando
Ya that 4puck would be horrible. Again the centerforce was good. It was drivable and held power. And then tranny issues followed.
Turbo powa!
Old 07-23-2019, 05:31 PM
here are pics of what I have. it was on the 3.3 motor with a 915 gearbox.
the part number on the PP is a little different. cant read the part number on the disk but would get a new one if I tried to use this PP and flywheel is a 930 part number.
Bob Cox
Old 07-24-2019, 01:23 PM
full quack's Avatar
Send a message via Yahoo to full quack
Call Chris @ TurboCraft...enough said!
Mark
Old 07-24-2019, 06:57 PM
Scottsdale Arizona USA
915 Sachs RE all the way
Best to stick with either the Sachs Performance / RE clutch or then the KEP. What to avoid would be the Sachs Power Clutch because the never last and fracture often.
The picture in the blue box is a standard 915 Power Clutch.
Pic 1 is SRE, notice higher quality materials and stronger limit straps. This is a very important feature.
Pic 2 : KEP clutch and disc. The disc features fuller face lining to that of the newer 915 clutches.
Pic 3 : SRE Clutch and EPW 915 225 Forged Steel Flywheel
KEP 915 Stage 1 clutch set : Great quality and value, very durable. Florged alumin cover, HD limit straps..etc.
Standard 915 disc vs SRE disc. Big cost and enginnering feature differences
Don't waste resources on this Power Clutch
EP-West // Automotive Part Connectors & MODE : Motorsport Design
1 (844) URO-PART // day@europartswest.com // mode@europartswest.com
Old 07-30-2019, 01:30 AM
