930 convert to 3.2 heads?
Hi all, curious to know if late 3.2 heads would be a nice upgrade on a 930 build?
Thanks in advance for any guidance. |
930 heads are made from a different alloy RR350. It has a higher ability to withstand heat than the 3.2 heads.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
I would rather be driving
3.2 heads can handle the heat no problem.
IMO, there is no point to do this unless you are chasing more power as part of an overall plan to increase induction and exhaust flow. Your engine is an air pump and you must optimize all aspects of the in/out flow to make it most efficient.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I’d stick with the RR350 930 head and have em ported.
do the bigger ports increase turbo lag?
im trying to reduce and bought another turbo that spools faster, but would like bigger ports but don't want to go backwards.....too much
Thank you all for the input. Decision made.
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
3.2 heads are a awesome upgrade... all depends on your goals. Leave as they are, or the sky is the limit...
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Are you using a 3.2 intake manifold? The gasket sealing surface is a different shape.
That's what I did - although plenty have run 3.2 heads at very high power levels without issue.
On the topic of temperature, I find it interesting that Motec says my head temps are much, much, higher after the car has idled for a relatively short period (5-10 minutes) than they get at any other time....
'77 S with '78 930 power and a few other things. |
Chain fence eating turbo
The 3.2 heads are a huge upgrade in my book.
The 3.2 heads will take the heat (boosted mine to 1.6 bar). This is getting to be an urban myth about the heads not taking the temps.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
All the 935 heads I have seen (pictures on internet) have been of regular alloy, not RR350. Those heads survived for 24 hours at 600-750 hp. Porsche probably decided on the RR350 alloy on Turbos, expecting their European customers to be cruising on the Autobahn or the like at very high speed for extended periods of time. The RR350 alloy probably gave them the added safety margin needed to let their cars run for 75,000 miles or more without needing to rebuild the engines more frequently, which would be unacceptable. This is of course just me second guessing why the factory did what they did.
(not being sarcastic; I learn something everytime I google stuff on this)The 935 heads I've seen photos of are all marked as using Y-alloy (Yttrium) heads, like the 2.4S (but not the T, E etc) heads (Y-alloy heads? Your 2.4S has 'em). Seems from that thread that all heads from the 2.7S up to the 3.2 (and including SC) were y-alloy heads - except the 3.3 turbos. As far as the difference between RR350 and "regular" heads, to quote myself from this thread The ideal Turbo head? 934? 935? Stock Turbo? Quote:
A delta of 200F is a pretty substantial difference - 50% hotter again. Read the spec for RR350 (its on wiki/in those threads); unlike y-alloy (which was developed specifically for aircooled aircraft cylinder heads), RR350 was developed for bearing housings in jet turbine engines, IIRC.. Although it was not unknown for aircraft manufacturers to use RR350 for their cylinder heads either... However, the fact that guys are running well over 600HP with 3.2 heads with no issues would seem to indicate that the heads just don't get that hot. Composition of the head alloy just doesn't seem to be an issue as y-alloy is fine- heck, the factory used it for the 935.... So the right thing to do is get your port sizes bigger/right-sized, you can probably use any head you like - YMMV. Others have, w/ no issues... As far as second-guessing what the factory did, and why, that's always fun, right? ![]() The 76-77 3,0 930s also didn't use RR350 heads (I did not know that until just now), only the 3.3 turbos (which I presume includes the 965, as there seemed to be only incremental changes to that). Even more interestingly, the factory also used RR350 for the 993 GT2, GT2 EVO and 3.6 turbos, (even when the bean counters were circled), despite RR350 being expensive (proprietary tech licensed from external supplier) and more difficult to machine... You could argue for the 930 that this was early days for turbo street cars, and the factory just played it safe initially; widely known that the 930 was originally a homologation special with an intended run of 400 cars for sale to the public so that the factory could go racing in Group 4 (and according to Starke, factory was worried they would struggle to sell even that many, and believed that almost all of the cars would be bought by race/club drivers and live as track rats- rather than being, as they were, widely bought by doctors, dentists, athletes, lawyers, gold medallion man etc. and driven on the street) And some things about the 930 - like the very cold plugs - were apparently dictated by EPA/DOT approval; changing them after the fact would have necessitated re-testing - so they just never did. However; they almost certainly had to re-test for later cars - like the 993s; which lost the cold plugs - but kept the RR350. Why? Darned if I know - it must have seemed worth it to them at the time...
