-   -   Cause of fluctuating MAP signal ? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1039511-cause-fluctuating-map-signal.html)
993Speedster 09-10-2019 06:56 AM
Just had a chance to read through all the available info. It seems here you're dealing with surge due to the distance between the compressor output/discharge and where you've chosen to take wastegate reference pressure (waaaaay further down the line close to throttle body). Take a pressure reference RIGHT off of the compressor housing and feed it to the wastegate instead of having a really long hose taken from much further downstream.
Here's my take... almost always with a mechanical wastegate, as RPM goes up; boost falls off a bit due to pressure drop across intake piping and intercooler at high flow. "Some" people like to reference wastegate AT the throttle body to account for these losses after all the piping. I don't like this in practice because there's now a REALLY long column of air and a slight delay. Combine this with a quick spooling turbo (you typically won't get this oscillation issue with that location of wastegate reference with a really big turbo with a lot of rotational inertia) and you'll get some wild oscillations.
If you want boost to not fall off slowly, add a boost controller; sourcing wastegate reference further downstream never seems to get good results.
spuggy 09-10-2019 08:33 AM
Originally Posted by IROC 912 (Post 10587133)
I dont have a boost gauge but the logs show an oscillation between 135KPA and 165KPa.
Yeh - really hard to see what things are doing without instrumentation... I suggested it as a check for the MAP sensor - but I also think it's pretty unlikely that the sensor is reading incorrectly. If the readings aren't insane, it seems far more likely it's showing exactly what it "sees" and working perfectly.
I probably look at the boost gauge more than the tach, a habit I picked up driving from driving with a 3DLZ - as, if it shows vacuum, lets you know how close you are to boost threshold.
The VDO "cockpit" or "vision" series visually match the factory instruments quite well - hardest thing these days is finding ones that only read up to 1 bar (25 or 30 PSI are much more common), especially if you like them to show vacuum as well.
IROC 912 09-10-2019 02:02 PM
Really appreciate the help with this issue everybody.
I'm not keen on hacking up my clean euro 3 gauge dash for another gauge so will have to look at some canbus options for my Infinity 6. I've got the infinity running my stock oil temp gauge with a lowside output and it rocks ... matches the log data precisely:D
I'll look for 1 discreet digital gauge that can be hidden easily to take care of this ... most likely something from this company .. https://gaugeart.com/product/gaugeart-can-gauge/
You can even configure it with a smartphone ... gotta love technology. I've got the materials to hook up a spare MAC boost solenoid and will tackle it this weekend. Will post an update with the results.
Cheers,
Sandeep
flightlead404 09-11-2019 06:46 AM
Cheers,
Sandeep
I can make you a custom panel to fit where the radio goes if you don't have a radio any more
spuggy 09-11-2019 01:49 PM
Your car; do whatever.
Seems to me having a display of the same MAP sensor info as the ECU is going from is kind of missing the point.
IROC 912 09-11-2019 02:23 PM
And now I understand your point. I've got a box full of old gauges and need to figure out how to add a small boost gauge to my original tach ... custom job I think.
Sandeep
spuggy 09-11-2019 02:39 PM
if 912 gauges (and thus dash holes) are the same size, could borrow a 930 tach and install stock boost sender for a pure electrical connection. Or use a temporarily installed mech boost gauge; on a boosted car could tee off the brake booster, or run a thin hard tube up the tunnel.
Unless you want a permanently-installed boost gauge (I find one useful), primarily to verify that the MAP sensor reading match reality - so you don't spend time chasing down an issue that doesn't actually exist...
IROC 912 09-18-2019 04:39 AM
Added the boost control solenoid this weekend and noticed some improvement in the MAP fluctuation.
Also noticed that the solenoid acts like a boost vending machine ... need more boost ? Just increase the duty cycle with a few keystrokes http://forums.pelicanparts.com/support/smileys/wat3.gif
Unfortunately (or fortunately), it also showed me how close my stock clutch package was to the edge of holding 0.5bar boost as at 10% duty cycle over stock 0.5 bar spring the clutch slips at 5000 RPM :(
Maybe the G50 upgrade is a little closer then I had imagined :rolleyes:
Sandeep
flightlead404 09-18-2019 09:35 AM
Sandeep
Which solenoid I'm curious?
The clutch issue is what's caused me a now 15 months of fun and anguish. I pepped up my car 2 years ago and the clutch started slipping when I punched it in 3rd. sigh.
And now I'm starting to re-think a full EFI conversion, I'm most of the way there anyway.
IROC 912 09-18-2019 09:49 AM
Im using an old AEM truboost (manufactured by MAC) 3 port solenoid. Easy to wire up ... +12v and a PWM ground signal. Its the blue unit behind the red pressure regulator.
http://forums.pelicanparts.com/uploa...1568828897.jpg
Thats why I love this car o' mine ... keeps me busy with mods :D Screw the purists ! :eek:
Sandeep
spuggy 09-18-2019 11:48 AM
Cool! Open or closed loop? What hz you running it at?
Heh... Also, overboosting (higher boost target) at lower RPM makes a big difference...
Oh, 915? ZF Sachs Race Engineering pressure plate worked for me as a 4+ year stopgap. You'll come to fear traffic, but it held 350 ft/lbs at the wheels...
Look on the bright side; if you were running more boost, you'd probably find it breaking the clutch free around 3500 RPM on anything over 1/3 - 1/2 throttle, which is a real fun dampener...
IROC 912 09-18-2019 12:32 PM
Closed loop at 30 Hz. Working on the PID values this weekend as the weather will be nice. Also have a classic car " Petite Grand Tour" at the end of the month through some local back roads and have to be ready to Hoon on demand http://forums.pelicanparts.com/suppo...ys/drummer.gif
Thanks for that. Reading up on how to use this strategy. Maybe high duty cycle below 3000 rpm to help spool and then shut off at about 3000 rpm to preserve the clutch :confused:
Lol .. I've got the majority of items I need for the G50 conversion already ... just need to disassemble the gearbox and take it for shortening. Decided that any money spent now should be put in to the G50 conversion.
Sandeep
spuggy 09-18-2019 01:10 PM
In case you'd not seen this: - Boost solenoids
Solenoids will "lose control" over the valve movement above and below certain duty cycles (pwm%) too high a percent or too low and the "dead time" of the solenoid will cause the valve not to cycle (stay open or closed), there may also be non-linear characteristics near the limits. The lower the frequency,the wider the usable duty range BUT there is more time lag to the next possible adjustment cycle. Compromise.
I tested various solenoids at different PWM frequencies.
I'm running mine at 25 hz, where 20-80 are apparently meaningful limits for the duty cycle.
Sandeep
Heh. Might as well convert to full EFI and lower the compression at the same time.
Because it sounds like you'll eventually be tempted to run 1+ bar anyway... :D
IROC 912 09-18-2019 01:58 PM
Thanks for that link. The duty cycle %age was 20% that caused the clutch to slip at 5000 rpm.
Is it a crime to search the want ads for used 930 pistons and cylinders ??? :D
Sandeep
spuggy 09-18-2019 02:38 PM
Yeh, season to taste...
I have boost control start at 110 kpa - so almost any boost at all goes to the top of the wastegate to help out the spring. This is what Motec suggest.
With closed loop, it's on/off until you reach target boost, of course.
On the Motec, there's a single-row table of target kpa against RPM (and the usual plethora of other trims/tables which can also modify the calculated value).
I know the PID values do the right thing on the dyno. Eventually. Which really isn't very useful, as I'm almost never WOT in 5th on the Mulsanne Straight...
In practice, I have about a 3 second window of BCV activation, and would like to both avoid overshoot and regulate quickly to the target setting.
That's a WIP, but doesn't seem impossible, just tedious to get perfect.
The boost overshoot to 220 kpa I experienced originally (which didn't cause the Safeguard to get excited) was what clued me in to what a difference it made...
Once the PID is dialed in, I was intending more boost up to 4500 RPM or so, and 1 bar after that. Maybe 1.1, 1.2 down low would be fun.
spuggy 09-18-2019 02:52 PM
Wow - 20% is basically "off". But if I interpret that correctly, applying any boost to to the top of the WG is enough to prevent it opening prematurely - and makes enough extra power that your clutch now slips...
My sympathies. I went through 4-5 915 clutches in a very short period of time, once I added the K27/HF, Kokeln & GHLs etc...
It really kinda sucked not to be able to use the power...
Heh. Why, no, no it isn't. 3.2 bottom end, right?
I have my orginal 930 P&Cs left over from the build. I went with 3.4 slip-in Nickies/8:1 J&Es.
Shoot me a PM if interested.
flightlead404 09-18-2019 08:19 PM
Sandeep
Well, If I trade up to some 3.5l P's and C's
But then I'd need to get new rods, bolts, head studs, rings, port the valves which means new intake and exhaust work, a new turbo to take advantage of that, twin plug the heads.............
IROC 912 09-19-2019 07:53 AM
I'm shooting for 400 RWHP in my 2200lb car ... should not be difficult with a 3.2L as my base and some 930 P/C, GT3582R and headers at 1.0 bar.
I had a beetle with EFI 2.4L Type 4 turbo, 98mm nickies, 80mm nitrided crank and twin plug heads by Jake Raby / Len Hoffman. That car had a G50 box in it and dyno'd at 375 RWHP and was scary fast to drive. The gearbox, EFI system and turbo I was able to keep.
Looking to have that same feeling again with the 912 :eek:
http://forums.pelicanparts.com/uploa...1568908204.jpg
http://forums.pelicanparts.com/uploa...1568908204.JPG
Bigtoe32067 09-19-2019 12:19 PM
That’s a sick bug and I’m not really into bugs. What did it weigh?
Tony
IROC 912 09-20-2019 09:58 AM
Tony
Recall about 2100 lbs. Porsche dreams but VW budget at that point in life.
