930 Aluminium vacuum pipe stub
Hi there
I have inadvertently removed an aluminium vacuum pipe stub from the inlet manifold area. I was prizing off the vacuum hose and the aluminium stub came off with it. You can see in the photos the pipe inserted and removed. The pipe is a good push fit and there is some evidence that it has been removed by accident before - there is what appears to be a light green transparent "glue" material in the hole where the pipe locates. It is also clear that if it had popped out before, no effort was made to key the surface of the aluminium. I would like to know if anyone has experienced this and what method of adhesion I should use for a good seal and permanent adhesive fix.
All thoughts are most welcome
Peter
Old 09-14-2019, 09:57 AM
JB weld should work fine. Make sure you have it oriented (clocked) properly, as you will not be able to move after it cures.
Rahl
Old 09-14-2019, 10:07 AM
my friend works at porsche and is currently restoring his 3.2. he takes a porsche karrosserie glue 2 K.
I will ask him what glue it is.
Old 09-14-2019, 11:31 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
I used JB weld on my pipe () over 10 years ago - still looks like I just a applied it and sealed perfectly (and have had the hose on and off many times since - no problems).
Last edited by Rawknees'Turbo; 09-14-2019 at 03:31 PM.. Reason: Forgot to take advantage of perv content!!!
Old 09-14-2019, 12:00 PM
Thanks guys - JB Weld seems a good bet ! What version of JB Weld was it ? There are quite a few types available ?
Old 09-15-2019, 12:51 AM
Thanks please let me know what glue it is. Thanks
Old 09-15-2019, 12:55 AM
