Scottsdale Arizona USA
Bob, for the brakes it all starts with wheel size if 17" or larger. If yes we like to run 993 Turbo brakes up front.
The 993 Turbo front rotors feature a removable hat that one would update with new adapter hats with Zero offset to the 911 SC hubs.
But...
Those 993 Turbo front rotors are too large for 930 calipers and require 17" wheels. You should be able to use the -81 930 front rotors and hats.
Your rears should be able to run the 930 rear brake discs to match those modified calipers...I think.
// 993T BRAKE ROTOR HAT ADAPTERS
993 351 911 00 : Brake Hat Adapter Set : Front : (1975-1981) 911 / 930 to 993 Twin Turbo Front Brake Disc Rotor - CNC Machined 7075 Billet Aluminum Alloy - Hard Anodized - MODE INC : EP-WEST USA
+ For use only with PNs: 993 351 045 10, 993 351 046 10 : Brake Disc Rotor
993 351 930 00 : Brake Hat Adapter Set : Front : (1982-1989) 930 Turbo to 993 Twin Turbo Front Brake Disc Rotor - CNC Machined 7075 Billet Aluminum Alloy - Hard Anodized - MODE INC : EP-WEST USA
The newer 993 Turbo Front Caliper Reproduction Set by Dansk.
82- 930 Turbo Hat Adapter to 993 Turbo Front Rotors.. note the offset.
996 Carrer Rear Calipers, Rotors and adapters to 911 SC arms.
Rear stacked ontop of front set showing sizes difference..
Here is the early style 23mm URO Parts master. They work okay but I think you need to add a base sealing washer. Dont recall right now but supplemented before.
EP-West // Automotive Part Connectors & MODE : Motorsport Design
1 (844) URO-PART // day@europartswest.com // mode@europartswest.com
Old 12-28-2019, 12:48 PM
911tracker85's Avatar
thanks again for the info.
I was talking to another guy who got rotors from Steve Weiner. he thinks he recalls Steve said he had to mill just a bit off the diameter on the fronts.
want to have the ability to use 16" wheels.
guess I'll wait until Steve is available after the holidays....
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
87 924S resurrect and gut and another track car...
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 12-29-2019, 06:14 AM
Yes the 993 Turbo Front Rotors are 322mm dia and you need to be 304mm. You would have to turn off some material everytime you need rotors.. Or you buy 78-80 rotor rings and special hats.
Vehicle Craft is another source for rotors they have made for this.
Found this old tread.. some got a nice package..
Originally Posted by 911 tweaks View Post
*** ...SOLD...***
NIB = new in OE boxes - brake calipers, front & rear rotors, brake pads, rubber caliper feed hoses, 2 steel lines for calipers, all hdwr, rear calipers machined for SC fitment...
EVERYTHING IS OE PORSCHE...see the boxes w/ PORSCHE p/n's on them...!!
**The calipers are no longer available & ZERO stock in US or Germany...if you ever wanted to do the ultimate complete brake system upgrade, here is your chance to do this with brand new never used parts...I paid over $5k for all that is here...$4500/bo shipped in cont USA...
Thx, Bob
Left Front cal 930 351 091 03...rotor 930 315 047 00
Right Rear cal 930 352 092 03...rotor 930 352 046 01
Left Rear cal 930 352 091 03...rotor 930 352 045 01
Right Front cal 930 351 092 03...rotor 930 351 048 00
2 sets of Porsche brake pads...964 351 939 03
Old 12-29-2019, 11:54 AM
Non User
infraredcalvin's Avatar
Bob, have a few days of good weather, so I grabbed the car, took a couple of pics for you, sorry no part numbers visible anywhere.
The fronts appear to be tuned down, look at the edge of the rotors where the drilled holes are right along the edge. You can see the clearance inside top of the caliper is very tight. Also, the adaptor hat is bolted, and my 76 hubs go on top with a spacer that came with my car, I’m pretty sure it’s the oe front spacer.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 12-29-2019, 09:14 PM
Non User
For the rears, it appears to be a standard 930 rear hat, but notice my calipers are mounted in the standard 930 location (my rear arms had the dogears, i machined flat, drilled and tapped them to fit the caliper. Stock spacer goes on top, but removed for pic. You would just need to be sure the calipers are centered over the rotor using the spacers you show in a few of your pics.
'71 914 track car
Old 12-29-2019, 09:19 PM
thanks for all that info and pic. in process of cleaning my front calipers.
Bob Cox
Old 12-30-2019, 05:40 AM
I'd love to see that, how the back of the calipers mate to the control arm.
as I was grinding away my dogears was wondering if possible to just drill/tap the control arm to use the 930 caliper bolt holes. but did not ponder this long enough to determine if that was not a viable option.
Bob Cox
Old 12-30-2019, 06:34 AM
Checked the costing today for the early Genuine Porsche Porsche front hats.
Once you get the hats and hardware (reproductions available), the Sebro rotor rings can be had for <$300 pair.
930 351 457 01 : Front Axle Brake Disc Flange Left / Right (1979-1980) 930 Turbo - GENUINE PORSCHE - List: $641.06 Ea (2 Req)
930 351 423 00 : Front Axle Brake Disc Flange Backing Ring - GENUINE PORSCHE - List: $228.60 (2 Req)
Use with 12x) PN: 900 075 057 02 : Hexagon-head Bolt (M6x16)
Use with 12x) PN: 900 039 002 02 : Tab Washer
Old 12-30-2019, 11:51 PM
