LinkBack | Thread Tools | Rate Thread |
1988 930 shuts off and no restart until cold
Crotchety Old Bastard
Oh there are a lot of threads on this topic. Relays, CDI, green wire, coil, coil wire, distributor, all or any could be the culprit. Because it is ignition related you can check at the beginning of the daisy chain and see how far you get until no power. Intermittent issues can be hard to trace but if it's heat related you can test things during that event.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
coil and CD unit are the usual top picks for heat related no start/no run.
I would start with the coil since it is cheap. you can listen to the CD unit with the key on. if it makes NO sound, it is bad, if does make a whine, it "could" be good. take a listen to it when it runs so you know what to listen for. if you buy a coil and that is not it its good to carry a spare. it saved me. I also carry a spare CD unit
86 930 42kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 05 BMW 330CI 130K:: [_ ![]() 08 VOLVO V70 190K:: [_ ![]() 90 B2200[__] RUNNING:[ ![]() ![]() |
"if it makes NO sound, it is bad, if does make a whine, it "could" be good."
Not all of them whine, the one on my '79 never did and it worked fine until I put the programmable MSD on. There was thread on the tech forum about this. |
Thanks for your post. This is the kind of experience-based info I was looking for. I'll test the coil and if that is good, do my best to test the distributor per the WSM. That CDI box sure seems expensive so it would be nice to rig up a bench test for it.
Few years back, my 87 had similar issues, get some heat in it and just stumble. Here's the kicker, the only way it would act up was under a somewhat of a lug in a gear, never under a pressure/boost situation. 12 years of driving, this thing never let me down sans 1 yellow overboost relay, which I knew from the past, would get me eventually.
When it started acting up, I had visions of everything that R8 mentions going wrong with my turbo, here we go. Being a neanderthal mechanic that I am, I did my due diligence and wiggled the red and black relays in the front, checked fuses for and aft, cdi whined like always, pumps good, coil new, boost held, ignition components proper. Eventually it was taken to my wrench, judging by the bill it wasn't much. So, what did he do? TTBOMK, he adjusted the air/fuel mix. I tried to pry more out of him, but I can see I would have a better chance finding out where my buddy gets his morrels. One thing to note, if my car would kill, I could push the clutch in while moving, recycle the ignition switch, and it always would start...albeit with a lean backfire (sometimes). My point is, if I were a betting man, I would have bet the farm on an electrical/relay issue, because of the heat issue...never bet against a 930! |
Some guys would carry an small ice chest with a bag of ice in it and when the car dies would put the bag of ice on the CDI box to cool it down. If car started then they would have the CDI rebuilt.
Rahl |
Had a very similar problem.....occasionally would die when warm and had to wait about 20 minutes before it would start. Tried everything but because it was so intermittent the problem was hard to diagnose. Finally decided to just have the CDI rebuilt. The Calif rebuilder is the guy to use...he gave me a modified loaner that had a micro lite that indicated power. He tested my old one ..it was fine initially....but left it on test overnite and it failed finally. Less than a $300 gamble and it paid off. I would suggest this before going thru heroics testing everything.
that's why I said check it when it is running and working,
Driver
I had a similar hot-start problem. Well, not exactly the same, as my car didn't shut off by itself. But rather, if the motor was hot, it would not restart. Finally (after everything else mentioned above checked out as OK) chased it down to the little black box under the driver's seat. So if you've exhausted all other options, don't forget to look there.
1987 Venetian Blue (really looks like grey) 930 Coupe |
Thread Tools | |
Rate This Thread | |
