what is this piece called
came off the intake manifold on from a 76 turbo, as you can tell i need a new one ... what is it called and where can i get a new or used one ????.. see following post. i forgot that you cant make a post then add an image via phone ..
Thanks in advance
Ned
Old 02-19-2020, 11:29 AM
Sorry I forgot to load image...
Old 02-19-2020, 11:32 AM
Alan L's Avatar
Don't know the name - Y pipe? But it is held in with some bog. Just because it came out doesn't mean it is no good. You have the same issue with a new one - still have to fix it to the manifold. I would try JB weld.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-19-2020, 03:49 PM
lake wales fla
Not 100 % sure but as far as know that part was never sold as a spare part.
All of them were installed with some type of epoxy and came with the manifold.
Old 02-19-2020, 06:03 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Another option for that diverter valve pipe, since it looks like it was broken before and someone attempted to repair it, is to take it to a hydraulics/hose shop and see if someone there will duplicate it for you.
Old 02-19-2020, 07:20 PM
Alan L's Avatar
Ahh -didn't see the break. Yes - I happened to be looking thru PET today for something else. Doesn't look like an individual part.
As Rawknees says, if can be repaired properly. Thin Al pipe - ***** to weld probably. Someone probably swinging on a hose snapped it.
Should not be too hard to fab in stainless. Stronger and easier to weld.
Alan
Old 02-19-2020, 10:28 PM
T77911S's Avatar
I just trashed one I removed from my intake.
sorry.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-20-2020, 04:39 AM
Thinking of making one out of 1/2 inch copper tubing ...
Old 02-20-2020, 07:25 AM
Send me a PM with your e-mail I may have a spare original part I removed from a de-smogged manifold. They were never sold separately.
Old 02-20-2020, 08:25 AM
Thanks i already have one on the way..
Regards Ned
Old 02-20-2020, 12:22 PM
I just saw this. I have several of these if anyone else is in need.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-21-2020, 03:50 PM
