oil relief springs 76 turbo
i was hoping someone could shed some light on this subject. my 76 turbo is from what i was told is an engine that should not have the oil bypass modification drilled out because it already takes it into consideration .. . as the case configuration is different.
so what's the deal with the big and the small spring according to all i read it says big on bottom small on top well both my springs are the same length and the pistons are the later smooth sided non drilled .. so should i have a big spring and one small spring or should i run the two equal length springs as were originally installed this way ? |
Ned,
According to the PET both springs are the same. 901.107.531.00 Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
Thats Rahl ...i like it lightly sweetened think i will use it when talking about mine also im mostly stock just a few little goodies rs raptor K27 andile intercooler sc cams .
