So many damn leaks- down the rabbit hole I go
Took the car out for a spring fling figuring the Covid-19 roads will be light and I could get a real thrashing in after a solid warmup and shakedown. Never happened... got about a mile away and had oil smoke pouring through my heater vents thanks to chronic engine leaks that make it to my heater boxes and through my frozen heater flappers. I’ve been denying that they need to be addressed but even that Egyptian river failed me this time and I resigned myself to dropping and getting into it. Of course, at 109k while it still has even compression I probably should inspect rings and mic up the pistons and cylinders. It’s no doubt time for valve guides & seals at a minimum. I bought the car with 58k with decent documentation and no known internal work.
Ken
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 03-22-2020, 12:59 PM
Dropping these engines is mentally harder than it is physically. It helps when my son is around due to the virus sent all the college kids home for the rest of the semester. But it’s still a precarious balancing and lowering operation, with lots of expensive things that gravity could easily have its way with. I’m glad it’s on the ground. Now I have to separate it and get the engine on a stand.
Ken
Old 03-22-2020, 01:13 PM
Work in Progress
Rich76_911s's Avatar
Damn dude, you move quick. And I’m always too nervous to jack the rear end up high enough to get the engine out without bumper removal.
I have leakdown and compression testers I could’ve sent up to you to check those.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 03-23-2020, 04:59 AM
Well done!! I'm also the victim of analysis paralysis.
Old 03-23-2020, 06:41 AM
Those tie down hooks that always scrape first on bad driveways were touching the floor but I squeaked by without pulling the bumper. It IS nerve-racking for sure!
I put the car outside for ONE DAY and boom... snow in NY. Amazing
Ken
Old 03-23-2020, 07:36 AM
Large Member
krasuskyp's Avatar
nicley done there, Kenster!
got mine out the 1st time that way, building a basic 2x4 cradle was clutch
2nd time on time on my lift w/ neighbor's hydraulic table was FTW 8-)
love you've put 50k on 'er! Here's to 50more.
Dude, my 67k motor looked exactly like that - and - I suspect may have been at least part of it's demise. Don't think I realized how much oil I was burning off the headers and didn't check it enough, foolishly thinking my 13qt system was fiiiiiiine. Hindsight 8 /
Best of luck w/ the reseal! My cam tower leaked after - I rule tho, you got this 8 )
and
roflmao @ the snowbit... dude, right? Can't make that up... love it heh heh
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 03-23-2020, 07:45 AM
Large Member
krasuskyp's Avatar
ps - what's yer tag read?
pps - noice to see the Mach 1 thar... titz
past:
Old 03-23-2020, 07:48 AM
I used a motorcycle/ATV jack and its much more stable
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 03-23-2020, 07:56 AM
gumba's Avatar
Is there a way to get the oil/oil residue out of heater boxes?
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 03-23-2020, 08:02 AM
Alan L's Avatar
Take it for a good thrash :-)
Yes - I finally got an ATV jack too. Makes a world of difference. Not expensive and stores away pretty good. Something to keep in mind for next time :-)
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-23-2020, 01:00 PM
Turbo Powered Snow Blower
Those are Brian's headers. The heat boxes screw together.
So yes he can just take them apart and clean them.
Derrick
Old 03-23-2020, 01:08 PM
Crotchety Old Bastard
RarlyL8's Avatar
We use pop rivets on the exchangers now, like that a lot better. When you put them back together use rivets.
Nice job attacking the leaks. Mine is beginning to suffer the same fait and I need to do this as well. Trouble is always time ...
Old 03-23-2020, 01:17 PM
“FRAULIEN”. The proper spelling for an unmarried woman in German is Fraulein, but that was already taken in NY DMV land. My wife calls the car worse names than that. And the car hates her right back. **** just goes wrong when she’s in it.
“Lien” is actually somewhat apropos given what I’ve spent over the years. Lol
Ken
Old 03-23-2020, 01:42 PM
TurboKraft's Avatar
Nice job going after the leaks
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 03-23-2020, 03:19 PM
lol I call my 930 the Schlampe Hausfrau
Old 03-23-2020, 07:08 PM
HaHa,
If you google that like I did. Make sure to turn the translator on before clicking any links...
I found the German Porn sites
Rawknee you probably have those sites bookmarked already.
Derrick
Old 03-24-2020, 06:43 AM
Originally Posted by 1979-930 View Post
HaHa,
That's funny, never thought of googling the phrase
Old 03-24-2020, 07:30 AM
Mutter ich werde gern bumsen
Old 03-24-2020, 08:53 AM
ugh.. I'm scared to look under mine.. Well done on getting after it!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 - Kokeln Intercooler - RarlyL8 headers/muffler - Leask WuR - Tial 46mm - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10
'99 4Runner Sr5
Old 03-24-2020, 10:08 AM
Who do "we" trust these days with looking over a 930 box? I don't even know if it needs anything but an honest inspection. I had Gary Fairbanks in CT go through this 8 years ago on the cheap just before he retired. I wish he was still around. His shop was a treasure-trove of air-cooled Porsche bits that only he could find anything in. Anyway, this box was usually touchy getting into first unless the car was stopped, and took a little more effort downshifting from 4th into 3rd (but only when it was up to temperature; cold it was fine). Both might have been clutch-adjustment related.
My transaxle:
Video of Gary's old shop. They don't make em like this anymore:
Ken
Old 03-24-2020, 01:30 PM
