930 turbo scavenge oil pump fittings question
Hey everyone,
I've been searching just about errywhere and can't find a clue on either the in-housing thread spec, or the stock (maybe?) blue AN-looking fittings on the camshaft-driven turbo scavenge pump. I'm looking to get an in-line filter + check valve (post-pump) and want to make sure I'm sizing everything appropriately.
Anybody know off the top of their heads?
Old 04-17-2020, 01:17 PM
If you're talking about the thread size on the scavenge pump itself, I believe the bottom fitting (intake) is an M14 and the top (discharge) is an M16. I had a lot of adapters from redoing the fuel and oil system, so it's a toss up. If no one corroborates me, Clewett Engineering sells a replacement scavenge pump designed for stock fittings, so give him a call and he can surely give you the answer.
Jonathan
'79 Copper 911 SC
'88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's
Old 04-18-2020, 12:56 PM
Rocket Scientist
You are correct. I just happen to be working on one. M14 x 1.5 on the suction side, and M16 x 1.5 on the pressure side.
Old 04-18-2020, 02:09 PM
TurboKraft's Avatar
M16x1.5mm inlet (hollow bolt, bottom, from turbocharger scavenge pipe)
M14x1.5mm outlet (adapter fitting, top, to tank)
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-20-2020, 09:24 PM
donbecker1234's Avatar
Does anyone have a part number or specs for the metal union fitting on the top of the pump that the cross over hardline bolts to?
Old 04-21-2020, 05:33 AM
TurboKraft's Avatar
Porsche does not sell that fitting separately.
Union is M14 x M16 concave (oil pipe side of fitting).
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 04-21-2020, 08:44 AM
Thank you Chris!
Old 04-21-2020, 12:33 PM
Russell Adapter Fittings 670520 & 670530
https://www.summitracing.com/parts/rus-670520
https://www.summitracing.com/parts/rus-670530
Good Luck!
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces for paint
Old 04-21-2020, 04:03 PM
Thanks Bill!!
Old 04-21-2020, 04:41 PM
Hmm - I bet Len (BoxsterGT) would know where to get them - and could make you a replacement line with it on; he seems to have sourced just about everything else fuel or oil line related...
'77 S with '78 930 power and a few other things.
Old 04-22-2020, 05:09 PM
Thanks, I've got all the replacement factory lines already, I just wanted to get a nicer/new fitting.
Old 04-22-2020, 05:51 PM
BoxsterGT's Avatar
Porsche Crest
Here are some "nicer/new" fittings.....
Most adapters of this type use a Copper Crush Ring at the component and a Male Cone at the Fluid Line or Hose.
I am happy to help given the thread sizes needed.
Len.Cummings at verizon.net
Old 04-23-2020, 03:35 AM
Tags
930 , oil , scavenge
