No issues with welding on the scavenge pump drive to my NOS 964 camshaft. I like the 964 camshafts with my K27/7200. I had thought I might need a bigger turbo but it's a good match imho.
Running great finally.http://forums.pelicanparts.com/uploa...1636370782.jpg http://forums.pelicanparts.com/uploa...1636370782.jpg |
I'm also using one of the Pulsar turbos (also recommended to my by kamaro). It's the GT3582R - I've got about 3k miles on mine and so far no issues.
My 60-1 drained to the chain housing and worked ok and then I drained my BW S366 to the oil drain plug. Neither ideal. Bit I never had a problem where oil was blowing past the cold side under high RPM and boost so there's that.
Motor will be 3.0 with 9.5:1 compression. For those that are using the Pulsar turbo, what are you doing with the water cooling connection? |
| All times are GMT -8. The time now is 01:21 PM. |
