Euro 3.2 + turbo : can I get away with 8 psi of boost?
I have been driving my turbo'ed Euro 3.2 for a while now with a 3.5 psi spring in the wg but now I feel bored with that level! .. so I'm thinking of rising the bar a bit more, I have an EFI via a Microsquirt and I'm doing the tuning myself, I wonder if I can get it to ~ 8 psi safely? .. I'm using a 91 fuel right now which is the highest octane in my area, but I can add a bottle of Torco to rise the octane if necessary, would like to hear from you guys about that, would I be "tickling the dragon's tail" by doing that with a 10.3 CR engine?
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 12-13-2021, 02:51 AM
Take out the guess work and install a wideband to really know how lean the engine runs at the higher boost.
Old 12-13-2021, 05:14 AM
Dr J's Avatar
Do you have knock sensors? Do you have an intercooler? What are your air intake temps on boost? The key is to avoid detonation (knock).
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 12-13-2021, 05:23 AM
Agreed. If you don’t have a AFR meter your guessing and hoping. Especially with your CR. I’d seriously consider a J&S safeguard as well.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 12-13-2021, 10:07 AM
David at Pelican Parts
Guest
Posts: n/a
Agreed, Air/fuel sensor/gauge air intake temp sensor/gauge. With boost comes great responsibility...to your engine. Following to see how the extra boost hits
Old 12-13-2021, 10:53 AM
I've got both a WB gauge and a knock sensor installed, my current AFR is around mid to high 10s at WOT. also I have a full bay IC with decent IAT (I saw a maximum of 90*F after muliple WOTs back to back).
Old 12-13-2021, 01:57 PM
Grappler
Rodsrsr's Avatar
@ 10.3 compression I wouldn't mess with it. I'm running a US spec 3.2 and only run .5 bar spring which is a solid 7 psi. You also have to think about the gearbox, not sure f your running a G50 or 915.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 12-13-2021, 06:29 PM
Mr. Merk's Avatar
What kind of power are you guys making?
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 12-14-2021, 08:57 AM
Grappler
Rodsrsr's Avatar
I haven't Dyno'ed it yet, but its a fresh 3.2, (new rings, bearings, arps, valve job, 20/21 web cams, enlarged throttle body, headers with outlaw). I'm guessing it'll fall in the 400ish range. No need to go hunting for more power until I upgrade the gearbox.
Its surprisingly well balanced in its current configuration.
Grappler
Know Gi / No Gi
Old 12-14-2021, 10:27 AM
The problem with high compression turbo is also the fact that your pistons are for NA, meaning the rings are higher up on the piston. There is less "room" for detonation resistance as it is.
I melted the ring lands on my stock US SC motor with a turbo under boost in what felt like 4 seconds of uphill load boost in cold weather.
I bet you could run 5 lbs and be ok with enough octane and fuel enrichment, but you will not get that magical turbo shove that comes from running 15lbs with proper internals, ignition & knock sensor control.
Old 12-14-2021, 11:55 AM
Brando
quattrorunner's Avatar
I don't even think it matters that the afr is safe, 10.1/1 is high and I'd be more concerned with ignition and boost. 8psi is just a bit high for that compression. Add meth or lower it to 5-7psi. These are not civics or ls v8's.
I definitely understand the temptation tho. You're stung by boost addiction for sure.
Turbo powa!
1977 911s. it's cool
Old 12-14-2021, 08:19 PM
After hearing from you guys, I think I will just let it as is and don't risk it. I will start saving some $$$ for a low compression Mahle 3.4 top end. Since I already run EFI and have a 930 transaxle, going to 3.4 low compression would be the natural next step. Only if its not that expensive to build!
-1987 928S4.
Old 12-15-2021, 12:53 AM
Brando
And you're using a 930 gearbox which almost requires more hp to enjoy it. I miss my 915 and more spirited days. when you get to over 400hp things start to get serious.
Turbo powa!
Old 12-15-2021, 07:42 AM
Jeff Alton's Avatar
The Euro 3.2 we did a turbo conversion we did, we replaced the pistons with 8.5CR to deal with 1.0 bar. The North American version 3.2 we turbo converted we will run at .7 bar but with programable ECU and dyno tune for best performance.
For what that is worth...
Cheers
www.turn3autosport.com
Old 12-15-2021, 10:24 PM
Keep in mind, that the 10.3 that porsche quote, actually cc's to a lower number. I cc'd a set of euro 10.3:1 pistons and got an accurate 9.8:1.
I think the general consensus is that the porsche quoted numbers are with a zero deck height.. there are threads around PP suggesting this.
It sounds to me like you could do it but just go gently
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-15-2022, 12:36 AM
onboost's Avatar
Cheers
10.3:1, 9.8:1 with the kinda boost you're looking to run she ain't gonna last long, and you'll be thinking about more than a gear box.. question is which will go first?
Typically the sweet spot is 8.0:1 -8.5:1 and 1bar as Jeff stated.
RGruppe #180
Old 01-15-2022, 09:10 AM
I heard that these engines are pretty much knock proof, I don't know how far that can be, but that what encourages me to rise the bar a bit at a time. And I'm fully equipped to get into the battle with a dedicated AFR gauge, boost cut tuned into the ECU,and a knock sensor.
-1987 928S4.
Old 01-15-2022, 09:14 AM
I've only had experience with normally aspirated, and they are definately not knock proof.
Always learning.
Old 01-15-2022, 11:33 AM
