Stephen B's Avatar
CDI replacement
The CDI box on my 85 is dead. I'm assuming it makes more sense to modernize with a MSD from everything I've read instead of spending $400 on a CDI rebuild. Any recommendations on a MSD model?
Old 07-31-2020, 07:45 AM
gumba's Avatar
https://www.pelicanparts.com/More_Info/ATCDIREPAIR.htm?pn=AT-CDIREPAIR
You can get your cdi rebuild thru Pelican for $310.00.
I had both my 6 pin cdi's rebuilt, as well as a 8 pin a few years back.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 07-31-2020, 10:44 AM
Stephen B's Avatar
Thanks Harold
Old 07-31-2020, 10:54 AM
What do you need? I have a CDI unit working when removed. Distributor also, if needed.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition, and EBC. SC cams, K-27/29, Tial 0.8bar, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 07-31-2020, 11:20 AM
Stephen B's Avatar
My distributor is good. CDI is original and finally pooped the bed. Thanks for the offer - I just ordered a MSD 6 AL and blaster coil. I'll get my CDI rebuilt at some point in the event I go back to stock in the future (which is highly unlikely)
Old 07-31-2020, 11:32 AM
PorscheMoparLiterbike
b5aar's Avatar
I think classic industries box is worth a look...bought their rear fuse block...high quality
Old 07-31-2020, 03:45 PM
speednme1's Avatar
I would go with a classic retrofit cdi if I were you
Rey....77 930 "the Mistress"
Old 07-31-2020, 05:01 PM
mark houghton's Avatar
I ran with a 6BTM awhile back....no issues with it. It provides ignition retard as boost builds, allowing you to run more pre-boost ignition advance to wake up low and midrange performance, then shave it off as boost builds.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 08-01-2020, 04:58 AM
