freesaints's Avatar
Electric turbo?
Has anyone seen these guys? I won't comment on the price (probably doesn't seem worth it for a nominal amount of hp/torque) but it seems to be an interesting idea. Can also be used with existing turbos to improve lag. Thoughts?
https://torqamp.com/
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 08-07-2020, 11:51 AM
These things are pretty legit, at least on smaller motors. The Cleetus McFarland youtube channel tested them out a while back and had pretty decent results. They tended to flow enough to build mild boost down low and into the mid range, but couldn't flow enough and tended to lose a few pounds of boost up top. If anyone has seen them, yeah they play up the redneck Florida man vibes, but they certainly aren't afraid to push components to the limit. And on top of that, they are pretty honest about results good and bad.
Here's the two videos they did on it. Single and then doubled up.
https://www.youtube.com/watch?v=7a_J2X88fSE
https://www.youtube.com/watch?v=_yrxbcB4CwA
Jonathan
'79 Copper 911 SC
'88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's
Old 08-07-2020, 01:06 PM
freesaints's Avatar
Jonathan, that's actually where I came across the Torqamp turbo, the Cleetus McFarland channel. Price aside, it seems like a two stage turbo setup like that would be a lot of fun - the electric turbo for low end boost transitioning to our stock turbos on the upper end: )
Old 08-07-2020, 01:24 PM
77 Restorer
Here's the video on the '86 911
https://www.youtube.com/watch?v=dfyCwKddNeg
Since it's episodic boost (up to 2 - 4 minutes max continuous) I wonder if it's amenable to even the 2.7l mag case...
Bert
77 911 Targa (Maize, or Talbot yellow as the case may be)
04 C4S Cabriolet (sold)
Old 08-07-2020, 01:32 PM
freesaints's Avatar
That extra horsepower and torque comes at a price just below $3k so I don't think it's worth it but dang, that would be a wild ride. Nice thing is that even though it's episodic boost - it takes 10 seconds to charge per 1 second of boost - it's not like I'm on boost that much to warrant that being an issue. Maybe a different story for a track rat but for me and my spirited driving, that would be a hoot.
Old 08-07-2020, 01:38 PM
77 Restorer
It does seem to be really interesting if you donít need higher end torque and playing in the lower side of 5000 rpm. Agree with the huge fun potential, but the price - and then you have to add the boot and filter and tuning as well. But if the price came down...
Bert
Old 08-07-2020, 01:45 PM
I wonder if you could T it in after the regular turbo's compressor discharge with an electric valve or something. That way you can open it when you kick on the electric turbo on the low end and have it closed to prevent air back flowing through the electric turbo when it isn't running. Or just go for a compound set up and feed the electric into the regular turbo.
Jonathan
'79 Copper 911 SC
Old 08-07-2020, 02:03 PM
77 Restorer
I think you're exactly right. They suggest this through a control box/ECU approach - https://torqamp.com/control-box/ . That way it helps with the low end and shuts off when the stock turbo hits.
Bert
Old 08-07-2020, 02:11 PM
I have invested less than $3000 to add a "real" turbo my 3.2, so I don't think its worth it.
-1987 Carrera Coupe,
-1977 911S with a Euro 3.2, single GTX3584 turbo, 930 4 speed trans, Microsquirt engine management.
Old 08-08-2020, 04:14 AM
freesaints's Avatar
Looks like they dyno'd a compound setup on a Supra 2JX turbo: https://www.youtube.com/watch?v=RWoZtDsYdwk
Also, pulled these from the comments:
In this case the TorqAmp is placed after the compressor of the turbo with a Y-piece. Before the intercooler there is also a Y-piece with a one way valve. This to make sure that at the low massflow the TorqAmp increases pressure and at the extreme high massflow when the turbo is on pressure the TorqAmp is no limitation because it is bypassed.
When the one-way valve is large enough it will be no limitation at all. We focus now on the 3inch version but bigger and smaller is also possible. Keep in mind that there is also air flow through the TorqAmp compressor (even when turned off) because it is placed in parallel to the valve.
Here are a few diagrams of implementation using their bypass valve: https://torqamp.com/bypass/
Old 08-10-2020, 09:11 AM
77 Restorer
Very cool options! Hopefully, as they become more established, the offering will become more modestly priced.
Bert
Old 08-11-2020, 12:36 PM
freesaints's Avatar
Bert, I agree. Although it looks really cool, and in a compound setup could address turbo lag, it's still pretty expensive. Probably not worth it from a pure cost-per-horsepower standpoint, but if the price were lower...
Old 08-12-2020, 06:42 AM
