T77911S's Avatar
camshaft seal
is there a seal on the left cam housing where the pump bolts up.
I could swear I took one out when I took my engine apart and it sure looks like one would fit.
when I rebuilt my scavenge pump I still had a leak there.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-05-2020, 02:36 PM
Hey bud- take a look here:
So many damn leaks- down the rabbit hole I go
Ken
1986 930 2016 R1200RS
Old 08-05-2020, 03:11 PM
Guessing this would be the same as the other side where the chain housing is mounted. Just changed that and would surprise me if they are any different. I put a thin layer of loctight 574 on both sides of the gasket and no more leaks. Anywhere i put that on as a sealer i stop any leak.
Gone!
Old 08-06-2020, 02:17 AM
There is a paper gasket at the housing to the head. Sealant would be fine, IMO.
There is a rear main type seal at the housing to camshaft. I don't think that is your question though.
Derrick
Old 08-06-2020, 01:25 PM
seal
I have this problem. is it difficult to change this seal? are there any photos or video?
Old 08-07-2020, 01:33 AM
Not difficult at all. Just be sure to remove the top valve cover and time the cam after you reassemble while you're there. Just remove anything in the way, including the rear sheet metal, lower the engine a little bit and you got access. See link below
Setting cam timing with engine in car?
Gone!
Old 08-07-2020, 05:44 AM
thank you very much for your comment
Old 08-10-2020, 09:14 AM
T77911S's Avatar
I know about the scavenge pump and seals .
yes, a rear main seal "type" that goes in the cam housing.
I could swear I took one out when I took my engine apart and it sure looks like one belongs in there,.
one did not come with my gasket set,
RACE CAR:: sold
Old 08-25-2020, 04:13 PM
T77911S's Avatar
I could swear I removed a seal and it sure look like belongs there.
I did find a 49x35 seal on line but not on pelican
RACE CAR:: sold
Old 09-06-2020, 04:24 PM
