K&N Air filter
Looking for the part number for K&N air filter kit that sits directly on top of the air flow sensor. We want to delete the stock air box.
Also a breather filter on the oil filler neck.
Thanks in advance!
Bernd Buschen "Bernie"
R Gruppe #357
1971 914/6 Original Owner
1970 914/6 GT Stoddard Built
1970 914-6 FNG
Old 06-11-2023, 02:29 PM
K&N: RU-5163.
Edit: I've been using this for 10years or so, and very pleased. Nice intake sound and clears up engine bay. As expected, NO noticeable power gains, and you do have to remove clean/oil periodically. You will need to cut a little notch in the base to clear the CO adjustment, and depending on the depth of your engine sound pad, you may have to lower the engine 1/2-1" to install. I've installed it with and without lowering engine, just easier if I lower the engine a bit, which only takes a few minutes.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 06-11-2023, 07:05 PM
Bucketlist's Avatar
This type of filter you can pick up on ebay - they come in a few sizes.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 06-12-2023, 02:17 AM
