930 back on the road !!!
well its been on stands for about 2 years due to broken head stud,
finally rebuilt the engine. working on converting to EFI. I put in all the sensors except throttle position and MAP. easy to do. I ported the heads. SC cams twin plug but running single plug right now. modified 7200 turbo I left the CIS on for startup and engine break in purposes, glad I did. started up pretty quick and no fiddling with it once it was running. initial run in went smooth. only 2 oil leaks, one before starting, I forgot to tighten an oil line to the oil tank and the other was an oil line at the scavenge pump. again, forgot to tighten it. man it runs great!!!! I cant believe how early the boost comes in with the new turbo.
I know the feeling... the first start is a relief for sure and it must feel great to check the 'RUNNING' box again!
Congrats!
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) |
Reading this gets me itchy to plate my car again. It’s been off the road for 2 years now. Occasionally I start it up and wash it.
I rebuilt the motor about 10 years ago then installed BB headers about 5 years ago. Last year I did the clutch. Just need to touch the key and it fires up with only the slighted smoke ( I can’t recommend True Seal rings enough ). I took it out yesterday to compare wing sizes. Which EFI are you running? ![]() Sent from my iPhone using Tapatalk
Never give up |
Pics or it didn’t happen.
Ken 1986 930 2016 R1200RS |
Congratulations! I can relate as my '76 had broken head stud and sitting for too long. Gives me some inspiration.
Now I just need some more money and time! Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
Work in Progress
Congrats what a great feeling.
I can relate too. Been off the road for way too long for me as well.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
hahaha minimum 5 pics as well! Congrats on getting back on the road boostinnnn!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
That is great news! Well done.
i must admit. I was a bit depressed when it broke and I took it apart.
then what to do to it. and the biggie that had my motivation down was putting all the time and $$ into and doing it myself and something going wrong, or it leaking like a Harley, (sorry Harley guys). about 500 miles. I still have the nervous over sensitive ear (yes deaf in my left one) for any strange noise or miss, same with the seat of the pants feeling for something not running right,
Is that normal? Is it supposed to sound like that? What's that? That feels different... Which EFI system are you using, or going to use?
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) Last edited by flat6pilot; 10-23-2020 at 12:30 PM.. |
Congrats on your rebuild and getting it running well!
MikeD '87 930 |
