The Bulletproof Valve Adjustment Solution
Hello air-cooled friends
I'm thinking of using this tool to adjust my valve's next springs when I pull my engine to change the clutch and the engine carrier.* Please give me your thoughts.* The Bulletproof Valve Adjustment Solution For Your Porsche!**See Short Videos Demonstrating How and Why SNAPGAP Works and . . . a One Handed Valve Adjustment in 1 Minute 10 Sec.* https://snapgap.us/ https://snapgap.us/pages/snapgap-installed-on-911 https://snapgap.us/pages/how-and-why-snapgap-works-1 Best regards Helio |
The only thing that worries me is the possibility for that little shim to fall off.
Hmmm, pretty cool method.
Am I the only one that finds the standard factory way with a bit of shim material or a bent feeler gauge to be quick and easy-peasy?
I guess it's what you are used to and feel most comfortable with. IMHO, doesn't get much simpler then the factory method, plus easier to track valve stem/seat wear with the factory method, as you are actually feeling the drag. At least that what I have done for the last 45 years.
+1
All these hey-look-at-my-new-gizmo methods seem like unnecessary complications. How much time are you really saving on a task that doesn't take that long to begin with? If you cannot judge how much drag is on the feeler gauge, should you even be doing maintenance on your 911? |
^+2
Agreed, never used one of those gadgets in over 40 years. Bent feeler is so simple. Or use the feeler holding tool. If you don't feel comfortable judging how the .004 should feel then use an .005, if it goes in it's too loose. if the .004 won't go in, it's too tight.
| All times are GMT -8. The time now is 05:59 AM. |
