FLASH SALE! 20% OFF CSF 911 Oil Coolers, 15% OFF Motul, 15% OFF Snapgap and More!
This weekend only!
Offer Valid: From July 23, 2021 - July 26, 2021
20% OFF Select CSF Performance Oil Coolers!
Now is the time to order that CSF Oil cooler you have been thinking about for your 911!
Whether its the new & improved OE style Front Fender Cooler, or the RSR Style front bumper oil cooler, CSF has you covered!
Take 20% OFF with promo code CSF20 at checkout!
Click Here to Shop Select 911 Oil Coolers!
15% OFF Snapgap Valve Adjustment Kits!
Take the guesswork out of adjusting your valves with this tool from Snapgap.
You no longer have to worry about valves being adjusted too tight or loose, once you have the valve covers off, adjustment can be done in as little as 15 minutes.
Use promo code SNAP15 to save 15% at checkout!
Click Here to shop SnapGap Valve Adjustment Kit
15% OFF Select Motul Performance Lubricants!
Since 1853 Motul has been providing the highest quality engine oil and lubricants for the world's racing and automotive enthusiast communities.
Motul's dedicated and driven approach to quality and innovation has kept them at the forefront of automotive world.
Not only being an industry leader, but also setting the standard by which all other motor oils are measured.
Now you can take 15% OFF when you use promo code MOTUL15 at Checkout!
Click Here for Motul!
25% OFF Schwaben 3/8" & 1/2" Digital Torque Wrench
Make sure you're applying the right amount of torque while you work on your car with this precision Schwaben Digital Torque Wrench.
Take 25% OFF with promo code TOOL25 at checkout!
Click Here for 3/8" Drive Schwaben Digital Torque Wrench!
25% OFF Strut Spring Compressor Set
Use the Schwaben Spring Compressor to change your springs safely and easily.
Take 25% OFF and Save $45 with promo code TOOL25 at checkout!
Click Here to shop Schwaben Professional Strut Spring Compressor Set
25% OFF Schwaben Cooling System Air Purge Refill Tool!
The Schwaben Coolant Air Purge Tool is an universal tool which creates vacuum in the coolant system in order to ensure no air pockets when refilling your cooling system.
Use promo code TOOL25 at checkout to save!
Click Here for Schwaben Cooling System Air Purge/Refill Tool.
Old 07-23-2021, 10:15 AM
Last chance to take advantage of these savings opportunities!
- $25 OFF Porsche Four-Cam 1/3 Scale Engine Models: https://bit.ly/3x9omLc
- 25% OFF Schwaben Spring Compressor Set: https://bit.ly/3i5hV7F
- 25% OFF Schwaben Digital 1/2" Torque Wrench: https://bit.ly/3i6c2ap
- 25% OFF Schwaben Digital 3/8" Torque Wrench: https://bit.ly/37gM0v3
- 25% OFF Schwaben Cooling System Coolant Air Purge/Refill Tool: https://bit.ly/3kYTR8A
- 20% OFF Select CSF Cooling Products: https://bit.ly/3x0vc5K
- 15% OFF Motul Performance Lubricants: https://bit.ly/36ZChsP
- 15% OFF Schwaben Scan Tools: https://bit.ly/3i5J22E
- 15% OFF Snapgap Valve Adjustment Kits: https://bit.ly/3744qiu
- 10% OFF 101 Project Books: https://bit.ly/3BKcv9W
- 10% OFF All Bentley Service and Technical Manuals: https://bit.ly/3rC0lvp
Old 07-26-2021, 11:03 AM
