Question 930 differential gears
Hello
'79 930 Euro , standard diff , non lsd
Replaced cv joints on LH driveshaft , in phase etc & reinstalled on car.
When in gear & just the LH rear jacked up with wheel removed ,noticed that when rotate the hub back & forth , there is approx 10mm rotational free play at the flange OD at the trans.
Is this typical ?
Old 04-30-2021, 01:32 AM
gearhead
Yes. It’s called lash. Too much is a sign of wear, but unless you’ve tracked it a lot it really best on it, it’s unlikely you have a problem.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-30-2021, 07:49 AM
Thanks for that , I know there should be some back lash , but was interested to know what might be too much
One never knows what a previous owner was up to !
Old 04-30-2021, 09:19 AM
