Vendor
Location: 155 Commerce Drive | Fort Washington, PA 19034
IN THE SHOP | 1981 930 Turbo
Hi everyone,
I wanted to share this immaculate 930 Turbo that stopped by last week for a Fabspeed Air Intake System and Maxflo Performance Single Exhaust (also available in dual outlet). With 79,xxx original miles this 930 is pristine, top to bottom. It's not everyday that you come across an aircooled gem which definitely had the whole shop's interest! ![]() ![]() ![]() Stay posted for videos! We are running 10% off with free Domestic U.S. shipping through the end of the month ![]() - Alec
Hamsa Naser Hamsa@fabspeed.com W: +1 267 742 3006 |
Ingenieur
Nice Euro 930.
Great Color and super clean!!Nice
88-930 Black / Tan 89-930 Grand Prix Wht 70 Trans Am Ram Air III 4 speed 74 Bronco Sport 302 Auto Beach truck for the Mutts |
Luvly.
Ole Skool - wouldn't have it any other way |
Clean early 930s are hard to come by. This color is quite nice too. I'll say it again as I have many times before 75 to 84 930s do drive the same as 85 to 89 930s. These early 930s were raw! Especially a 78/79 930 on 7 and 8 inch tires!
http://9309700485earlyturbo.wordpress.com |
Vendor
Thank you everyone! Always excited to see a clean 930
Vendor
Nothing like having another 930 in the shop!
Nice! Not many Pacific blue 930s out there
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
After looking again it appears to be black. Dam old eyes
Vendor
Take a look at our founder, Joe Fabiani, as he explains our upgraded Turbo package for the 930!
https://www.youtube.com/watch?v=h8JQcpPyaF0
Enjoyed the car and video!
'79 930 Minerva Blue/Cork '98 993 Cabriolet Glacier White/Midnight Blue Fire - '91 C2 Targa Black/Tan |
I enjoyed the video but when I went to the website I didn't find the (orange) Turbo inlet outlet hoses that he was selling in the video. There is an adapter available using an o-ring which he says is old technology. I might be interested in the conversion to eliminate the o-rings but probably not in orange.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
Vendor
Vendor
High performance long-neck intercooler upgrade engineered for optimum flow efficiency and maximum cooling, lowers intake temperature while improving flow for maximum power gains.
Developed of our own project street and race vehicles, fitment and function was incredibly important for us. The increased surface area and internal volume allows for much greater heat dissipation, increasing power and sustaining it by preventing heat soak. Not just for track use, our intercooler also shines on a street car where the OEM intercooler falls short from the factory. The silicone hoses reduce any risk of tearing and smooth air flow while the replacement bypass valve is designed for performance use; drive your 930 passionately and enjoy the increased reliability, power, and sound. Included are silicone tubes that ELIMINATE all leaky O rings. Silicone hoses guarantee all boost is obtained all the time. The Long-Neck term refers to a intercooler outlet extending and connecting directly to the throttle body. The Long-Neck style intercoolers serve to replace and do not intermediately pass through the original equipment air by-pass valve system, also known as the shuttle valve The Air by-pass Valve System. These large and heavy systems were found on the 930 Turbo models and later updated / removed by the factory. The housings were an intermediate component between the intercooler and the intake manifold with integration to the Bosch K-Jetronic emissions control system. The assembly serves to regulate and by-pass excess pressure back into the intake circuit. It does this with a vacuum actuated piston, compression spring and diaphragm regulator. These are wearable components are often the cause of common drivability problems and lethargic engine response. Input ports for the boost gauge and limiting sensors are also referenced on this assembly. The 1991-1994 965 C2 Turbo models updated to a less complicated, lightweight boost control valve. The Fabspeed intercooler also removes and converts to the long-neck and newer style boost control valves. This greatly improves drivability with sharpened boost response further enabling the turbocharger to spool up quicker. FEATURES: Fits all Porsche 911 Turbo 930 vehicles worldwide including 930S slantnose. (1978-1989) Available for factory OEM turbo model LDZ or upgraded K27 turbos Increases horsepower and torque by 40 whp and 29 ft-lbs Flow as much as 900 CFM @ 2.6/1 pr ratio with less than 1 PSI drop Cubic inch volume mass increase from 258 Stock to 650 cubic inches. C2 Turbo long-neck style with no O-Rings for a leak proof charge. No more 1950's - 60's failure prone O-Rings. Intercooler Kit includes bypass valve, bypass sleeve, rubber elbow, 5-ply silicone hoses, and all mounting hardware necessary for installation. Utilizes factory fitting location with water/methanol injection port included. Includes gaskets and shields to seal intercooler to stock deck lid like the Porsche Factory System. Direct bolt-on replacement for OEM intercooler. An improvement is design, function and style over the Koekeln intercooler. All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
Vendor
Happy to provide Ceramic coating on the intercooler as well, any color!
