930 engine rebuild
Hi guys,
I am about to rebuild 930 turbo for piston problems... I have timed 964 engine earlier, but could not find much details about 930 turbo, 83 model.. can you help me with the timing specs for this amazing car ? How much hard do you think that the timing is of this car than compare to 964..? |
it depends on the cams you use.
they are easy. I had to re-time one side and I did it with the motor in the car, the right side only of course.
ignition or cams? if ignition search for ultimate timing thread. you don't mention if you are using a distributor or something else.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Might be a good time to pick up Wayne's How to Rebuild your Engine Book
The cam timing process is no different to an SC. Straight foward - if a 911 cam timing can be called straight foward.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Preferred pronoun:Maestro
_
When in doubt, use overwhelming force. |
This is an off the wall comment from someone who just installed a rebuilt engine and trans into his 930 and thoroughly enjoys it, but since you are at the decision point of investing a lot of cash into a rebuilt ... have you considered converting your car to EV? There are kits out there, EV West is just one example. In a few years the govt will start to figure out how to penalize ICE transportation forms, so considering an EV conversion may be worth considering, depending upon your longer term plans for the car.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
