Supercharging What happened to that??
Hi, it's 3 Pedals again. 79 911sc. Stock 3.0 CIS with hydraulic cam tensioners. 100, 000+ miles on the car. I'll have to go through all of it, but for 'down the road ' I want to supercharge it. It's low compression and I think it would be the least expensive way to go for more HP.... with out stressing the bottom end and spending a pile of money to turbo charge it. This is a lower budget build, I just need more HP, but I'm not going to push it to the limit every time as I need this one for longevity and fun. Comments and constructive ideas are most welcome Pelicans.
Old 10-09-2021, 07:10 PM
Dr J's Avatar
If you wanted to do it, get something like this.
Paxton SN2000 Supercharger for 3.0 911 Engine
Shouldn’t affect idle much and would increase power in a sort of linear fashion so it’s easy on the 915 transmission. It probably won’t generate much heat while cruising since it would not be compressing much there. This means you can get away with no intercooler. Should be a lot of fun and getting a complete or nearly complete kit is not easy for the air cooled engines.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 10-09-2021, 07:42 PM
908/930's Avatar
l was looking at a company that produces kits for bmw's and others, VF engineering, turbine type blower, low boost levels vs what is capable from a roots or screw blower but still enough to give significant increase in efficiency vs trying to mod cylinder heads. I think the life expectancy of all of these units is the problem, not sure what that really is. Also supercharger put a little more stress on the bottom ends, they developing some boost at low RPM.
Old 10-09-2021, 11:24 PM
gearhead
I saw that listing. That’s a nice kit. If I had a 3.0l I’d been interested.
Old 10-10-2021, 09:01 AM
With prices at around $10,000 life expectancy would be an issue for me.
Old 11-01-2021, 06:46 AM
I’m in the same boat let me know what you come up with I’ll do the same. I did see a stock 3.0 running a sort of bae set up on YouTube not sure if it’s any good or not I’ll see if I can put the video up.
Old 11-01-2021, 06:48 AM
Old 11-01-2021, 07:01 AM
Jonny H's Avatar
^^^. Nice to see the CDI+ Launch Control feature in use!!!
Old 11-05-2021, 04:39 PM
M5guy's Avatar
As an aside, I had a Paxton on a 66 Shelby GT350. Reliable old school unit. On the Mustang the carb was completely enclosed in an air tight box with the supercharger feeding it. Nice setup but obviously not for a flat six.
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette.
Old 11-07-2021, 07:12 AM
