Drive it like u stole it.
jonesb930's Avatar
Twin Turbo Oil Return sump tank
So I was trying to come up with a compromise between returning the oil to the engine sump and using the custom scavenge pump from Clewett Engineering that includes the cam sync sensor. I figured gravity to a common tank then connected to the sump pump to return the oil to the tank just like it did originally. See my concept bellow and please comment. I am looking for any opinions before I weld this thing up. The turbo's will drain into the top AN12 bungs on each side. The return bung, left side bottom, is an AN8 (recommended by Clewett). The bottom bung is a 14x1.5 for a drain plug. I figured I would mount it as low as I could safely do so, making certain that it does not get damaged if I go over something on the road. The material is 6061 aluminum, .125 thick.
I plan to make the drain on the turbo out of 304 stainless using 3/4" tube and AN12 fittings to allow free oil flow.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 11-12-2021, 12:16 PM
TurboKraft's Avatar
Done that on a dozen engines, works fine.
8AN is plenty large for journal bearing turbos, even for the return to the pump.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-15-2021, 03:18 PM
jonesb930's Avatar
Thanks for the reply Chris!
Bill Jones
Jupiter, FL
Old 11-15-2021, 05:17 PM
This is what I ended up making. Same concept as yours: two ports for the turbos to drain into and a third lower port for the pump to pull from. Even after this engine build (twice), I'm still new to fabrication, but it's functional and more importantly doesn't leak.
Jonathan
'79 Copper 911 SC
'88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's
Old 11-15-2021, 11:49 PM
jonesb930's Avatar
I intend to add a breather to mine as well. Just not sure what side of the tank yet until I start looking at everything else that may be in the way. I figured I would plumb it up into the engine bay like the original tank.
Bill Jones
Jupiter, FL
Old 11-16-2021, 07:40 AM
