Tracing oil "sweat"
Hi everyone,
I am trying to trace remaining small oil "sweat" around my engine bay (86' 930 with 88k miles). Will be addressing oil level sender gasket today but this one (pictured below) is bit of a mystery to me. The pipe i marked seems to gather oil very very lightly and cannot figure out where it is from. Picture taken below was before i cleaned it up. Now this area is cleaned and dried up till the next few drives but any input where it could be from?
My suspects oil pressure relief? but those are not around this metal line to get oily.
Much appreciated
Old 01-14-2022, 11:56 AM
stevie 77 930's Avatar
On the drivers side on the rear of the motor is the turbo scavenge pump.
There are some sealing washers on both the inlet and outlet pipes. Check and see if the bolts are secure or need new washers.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 01-16-2022, 06:08 PM
Thanks for your suggestion, just checked and that area looks dry
can the oil crossover pipe from engine leaking on this "fuel line" ?
Old 01-17-2022, 09:56 AM
