-   -   -0-,nada,none compression (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1110313-0-nada-none-compression.html)
O.B.1 01-09-2022 05:10 PM
Hey Guys
Fired up my ‘87 930 after it had sat for about 3 months and it has a miss. So changed plug’s and wire’s and the miss was still there. Did a compression check and all cylinders checked with 105-115# except for #2. Gauge would not move from zero on 3-4 checks. Double checked Gauge and it is good,no leaks on test hose all O rings in place. Double checked #5 and got the same reading as before (110#). So …going to do a leak down on #2 tomorrow and hopefully get some idea where to go next. Is there a possibility that a intake/exhaust valve has stuck open from sitting?
Any ideas or guidance would be greatly appreciated.
Thank You Guys!
JJK78-951 01-09-2022 07:52 PM
That sucks. Leak down will give you a better idea. Anything is possible but i'd pull off the valve cover and take a look, may have a broken rocker or something.
Good luck
J
dannobee 01-10-2022 04:48 AM
Leakdown test, as suggested, and listen for where the air is leaking. Intake, exhaust, or crankcase. That'll give you a better idea. And borescope that cylinder it with a camera if you happen to have one.
T77911S 01-10-2022 07:13 AM
probably carbon holding exhaust open.
you can check the valve adjustment, which I would do anyway. (not that it changed while sitting).
Alan L 01-12-2022 04:17 PM
Yes - you should be able to see the problem with the LHS valve covers off. Maybe a stuck valve. Even with a bit of carbon on the seat I would think you would register some compression. Low(er) , but some. If it is simply a valve that is not moving as you turn it over by hand (plugs out), a bit of CRC over it and a gentle tap may free it. Hard to think it is a piston problem - which really leaves you with the valves. Maybe carbon on the valve stem.
Alan
