3.0 turbo retrofit to long neck Ic help
Hello
I was hoping to find a line diagram on retro fitting a 76 /77 3.0l row turbo to use a long neck intercooler with a blow off /bypass valve with the original cis system.... Because of the ic retrofit and blow off valve I'm a little confused on where all the hoses terminate... Fyi im using a 77 throttle body as my car has a brake booster . Obviously once im 100% sure of what goes where i will be replacing all associated hoses... Thanks in advance fyi its an early 76 intake manifold. Cant believe those welds are stock guess welding magnesium was not as refined as it is today. ![]() |
Hi, are you trying to fit an old ANDIAL Longneck intercooler made for the 1976-77 Turbo Carrera, or a newer one made for a standard 3.3 Turbo?
If you're using a later one (TurboKraft, Kokeln, ANDIAL, etc) then you need a 3.3L intake manifold because the throttle body sits at a different angle than on the 3.0T. Or cut and re-weld the intercooler outlet. BTW: all the 3.3L manifolds have a brake booster vacuum port between cylinders 1 and 2.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Chris the ic fits perfect its the early one for the 3.0 my 77 throttle body has the brake booster Take off.. Im just a little confused on How to plumb the blow off and the bypass. These two things a simple line drawing would be great...
![]() Last edited by gorskined; 12-23-2021 at 10:16 AM.. |
Where do the 4 question marks connect to i have plenty of take offs on the intake and the intercooler. I just need tp know what one goes where.
![]() Last edited by gorskined; 12-23-2021 at 10:27 AM.. |
7.0:1 > 11.3:1 > 7.0:1
Hmmm, 965 BOV elbow needed? This is the common retrofit for the 3.3 intake system. See the second picture on the first page.
Blow off valve location |
![]() A = boost pressure sending unit, M18x1.5mm B = overboost pressure switch, M10x1.0mm C = vacuum limiter, aka deceleration valve D = diverter valve E = auxilliary air valve Sometimes there are (2x) M10x1.0mm ports, and the 2nd one is for the wastegate pressure line. Other times there is a nipple or port on the inlet side of the intercooler. The vacuum source for the deceleration valve is from below the throttle plate, and it can be shared with the diverter valve.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft Last edited by TurboKraft; 12-23-2021 at 03:15 PM.. Reason: edit |
Sometimes pictures are better than words.
Arrow points to hose from Intercooler to bov. ![]() Circle around bov mounted in 965 elbow. ![]()
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
Thanks guys so the metal thing is the deceleration valve. Im Assuming i still need it what exactly is its purpose? .. If i reading this correctly it basically a bypasses for the throttle body? that run from the intake to the back side of the intercooler? .... The two take
offs are offset are they directional?... ![]() Last edited by gorskined; 12-24-2021 at 07:58 AM.. |
First thing to check is whether that vacuum disc still holds vacuum or if the diaphragm is torn. If it still is intact you can consider using it. The decel valve helps reduce popping and burbling on deceleration and supposedly can help keep boost up between shifts.
Here’s a photo of my Turbokraft long neck IC (for 3.3) that might help you. ![]()
Ken 1986 930 2016 R1200RS |
I ditched my decel valve years ago. Didn’t notice any difference other than previously mentioned popping and gurgling
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
great so the center take off goes post throttle body and the side one connects pre throttle body
Thanks for the info Regards Ned |
On the blue 930 I deleted as many of those devices as possible. It now starts and runs 100% better. Just installed a wevo and at same time hooked up the existing manual throttle lever. Cold start is now a joy. The aux air valve would idle up so high that it would wake the dead!
Dsm what's a wevo?
