-   -   case trans stud length for starter (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1112747-case-trans-stud-length-starter.html)
gorskined 02-14-2022 07:56 AM
I need to know the total length of the stud that connects the top of the starter to the transmission and the engine case .. The one with the 10mm Allen nut .. my car currently had a bolt and i would like to replace it with the correct stud . i made the mistake of putting it in the car before i replaced it , so trial and error is not an option.
I searched some old threads and find conflicting information and the links provided are no longer good.
Thanks in advance
Regards Ned
356911930 02-15-2022 03:08 PM
Ned, I’m pretty sure it is M10 X 115mm. Unfortunately I am not 100% sure so you will need to double check.
Best of luck,
Rahl
gorskined 02-17-2022 05:17 AM
I removed this from a old 2.7l case I forgot I had 122mmhttp://forums.pelicanparts.com/uploa...1645107421.jpg
