How to make 86 jetronic work in 79 930
I’m a newb when it comes to CIS and 911’s. I am building a 79 930 that I purchased as a rolling chassis. I then purchased an 86 3.3 turbo engine with harness and jetronic box. I can’t find any reminents of such a control unit on the 79 chassis. So my questions are
1) what does the jetronic ECU control? Is it just 02 sensor? 2) does the ECU get its power from the engine? What all needs happen Ike’s up to make it run? 3) Can you identify the connectors in the pic marked with an arrow and tell me what their function is? Thanks for your help. I’m pulling out my already rapidly decreasing hair. I’ll include a pic of the unit and wiring for reference |
Those look like standard plugs.
From memory I am running an 86 engine in my 82 chassis. There was a TPS on the engine - which I don't use. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Do you have anything else in the cabin under the seat that is hooked up to the module? Sent from my iPhone using Tapatalk |
Nope.
Diagram links
Mine is a RoW car (ex Japan), so I think it is missing some bits yours may have - incl that box.
Alan
My wiring is for the 82 engine type (same as your 79). And it has all it needs to run the basics on the 86. There is no lambda loop, TPS, speed limiter thing etc. Doesn't need it.
Alan
I talked to Brian @rarly8 and he’s going to convert my stuff so I’m all good thankfully
Thats a good plan. Can't go wrong.
Alan
