-   -   cis sensor plate stop (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1115015-cis-sensor-plate-stop.html)
gorskined 03-18-2022 08:38 AM
part # 928-110-924-00 the rubber stop Attached to the metal bracket that runs across the top of the sensor plate. so what the deal with this? does this stop actually have a function other than a anchor point for the factory air box? ? i have two 930 cis systems and both stops are at least 2 to 3 mm away for the sensor plate nut.. i don't see how this stop has a function. Other than the rubber coming loose and getting sucked into the turbo. hence my Question do i need it? im running a K&c cone filter .and if i do how should the stop be set?
356911930 03-18-2022 12:46 PM
Way back in my cobwebs I recall this being for keeping the arm from bouncing creating caring air flow or some such thing. Maybe this will ring a bell and jog someone else’s memory.
Rahl
Bucketlist 03-19-2022 02:53 AM
I was curious about this a few years ago. I removed it when I switched to the cone filter. I didn't see any difference.
Alan L 03-19-2022 07:38 PM
It has always puzzled ne too - for same reasons. My car did not have one, so I ordered and fitted one. But I am still struggling to see the point. Unless it is some sort of backstop for a backfire?
Alan
gorskined 03-21-2022 04:16 AM
Alan
i thought the same but there is no play in the sensor plate arm to go that far back.
