930 intake manifold insulator question
are there thick insulators between the heads and intake manifold? or just the basic gaskets?
Lorne M
83 SC
Old 05-10-2022, 09:31 PM
Drive it like u stole it.
jonesb930's Avatar
There is a thick insulator on the 930. See # 7 in the image.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 05-11-2022, 03:00 AM
Im running large port S/C heads with a ported 930 manifold. So, I’m using aluminum as opposed to the stock phelonic spacers. I don’t have any insulators between the heads and spacers. Just gaskets.
Any wisdom as to weather I’ll experience excessive heat soak ? If so, does anyone here know where to get 38mm thin spacers ?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 05-11-2022, 07:37 AM
Thanks that diagram shows the gaskets better than the one I have.
the residue/ remains of the old gaskets make it look like there was a Carrera style insulator there not the paper thin gaskets shown.
Thanks Lorne M.
83 SC
Old 05-11-2022, 08:36 AM
I have Turbokraft CIS blocks, which come with an insulator and gaskets. Not sure if they sell the insulator separate. Also worth noting, I think the actual aluminum block is a few mm shorter than the factory plastic block so that the aluminum block plus the insulator equals the height of the factory plastic block. If yours are already the same height as the factory plastic blocks, you might need longer studs - though I guess it could impact clearance between air cleaner and rear shelf.
Old 05-11-2022, 08:53 AM
T77911S's Avatar
you cant just add insulator blocks or remove them as it will change the height of the IC.
i have turbokraft with insulators.
i am always amazed at how cool the top of the 930 engine is.
be aware of how the gaskets go on. they do NOT go on the same direction for both sides.
with the plastic IB's look at the surface of the blocks and make sure they are not deformed. they should be flat.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-11-2022, 10:01 AM
Thanks for the info fellas. I’ll have to measure my aluminum blocks against the originals
If they’re shorter I’ll see if Chris will sell me a set of his insulators separately.
Apologies to the OP for the high jack
Old 05-11-2022, 11:40 AM
Banned
check your OE plastic injector blocks for cracks - common w/ heat & age
and beware not to over torque them... will crack 'em
Old 05-11-2022, 05:55 PM
Alan L's Avatar
Change to Al blocks (TK) and as T77911s says - take some care looking at the gasket orientation. I did a post on it years ago (prob never find it again) . Get them wrong and you have next to no sealing.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-11-2022, 11:42 PM
jonesb930's Avatar
Interestingly they refer to it as a flange (injector block makes more sense). The image is from the 78-83 parts catalog (available on the Porsche Classic website). My 75-77 catalog has no mention of the 930 that I can find. The Porsche Classic site only has what I have I once had factory micro fiche with everything but sold them off long ago. Does anyone have a parts catalog for the 75-77 930?
#7: 930 110 141 03 - Flange qty:6
#8: 930 110 197 10 - Gasket qty:12
Bill Jones
Jupiter, FL
Old 05-12-2022, 04:22 AM
T77911S's Avatar
Alan
i did one too. at least on my car if i put them on wrong there was only about 2mm of gasket at one of the edges.
RACE CAR:: sold
Old 05-12-2022, 07:46 AM
Thanks for all the information, I did find the post showing how to put the gaskets on properly,
Thanks again Lorne M.
83 SC
Old 05-12-2022, 08:16 AM
