Windscreen washer
Hi fellas
I have a 77 911S with a poorly windscreen washer pump. It seems to be mounted on three rubber bungs I assume to stop vibration. I need to replace or repair the said pump but cannot see how to remove it.....and advice Thanks |
All sorted....just pull the pump and bungs away from the bulkhead making sure you do not damage them as they are ridiculously expensive for bits of rubber.....although at my age I think everything is expensive !!
| Tags |
| 77 911s , windscreen washer pump |
