Throttle rod, bent? Braze joint broken
Cleaned up the throttle rod, the braze joint was broken, after some aggressive wire brushing I attempted to re-fuse it with MAP gas, and it did fuse but not what I would call a good joint.
![]() The brazed wire end of the rod is bent out of plane with the upper section, I am guessing this happened when the previous owner replaced the clutch? Am I correct in guessing this should lay flat and not bend up as shown? ![]() ![]() I could easily correct the bends and then get out the oxy acetylene and redo the braze. I have an old nickel silver braze rod that is about 86,000 psi tensile strength, am guessing this is what the factory used. Anyone got some pictures of a good throttle rod? Doing more guessing in this post that I am comfortable with David EngiNerding Last edited by reclino; 05-12-2023 at 01:19 PM.. |
![]() ![]() Sure looks like mine has hard a rough life. My loop end seems to be twisted clockwise along the axis so it is also out of plane .... Wonderfull Got all the bends fixed, and discovered my Oxygen bottle is empty. Last edited by reclino; 05-12-2023 at 01:20 PM.. |
Yeah, oxy is the way to go. Should get a nice join. The angles are not critical. I just refitted my engine a few days ago and got a bit of a bend in that part of the rod doing so. It was caught up above the engine as the engine went in. Had to tweek it a bit to get it clear below. But it is not critical - the ball socket takes up plenty of misalignment.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
This is so thin mapp will be more than enough, propane will do it.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
The previous attempt looked like a lack of heat. I think he correctly identified the problem.
But yes, some care wil be needed with oxy. Small flame, not blasting it away. I do agree tho that you would have thought propane etc would have got hot enough - but apparently not. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) Last edited by Alan L; 05-13-2023 at 10:01 PM.. |
![]() ![]() Good enough for me. On to the next problem... |
