Aluminum turbo calipers on a 1982 SC
Hi Everyone
I have a 1982 911 SC with bilstein struts that came with A calipers. I have a set of NOS aluminum brake calipers that I believe were for the 930 turbos. I’ve measured the bolt spacing on both and they are at 3.5 inches. Would these turbo brake calipers work on my SC. Thanks in advance.
Old 01-21-2023, 08:56 PM
Titanium User
Yes, they will fit. If you want to upgrade go with a 3.2 Carrera caliper. You need matching rotors because they are thicker.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 01-22-2023, 06:14 AM
I think that your rear trailing arm caliper bolt spacing is 3.0” and the turbo brake calipers are 3.5”. You should double check.
Rahl
Old 01-24-2023, 10:39 AM
The 9 Store
Originally Posted by jess p View Post
Hi Everyone
Yes.
All used parts sold as is.
Old 01-24-2023, 11:02 AM
Non User
infraredcalvin's Avatar
Just happened to stumble on this old thread, info applies:
No booster 930 brakes
There is info on the mod needed to make the calipers fit on the rear 3 inch spacing.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 01-24-2023, 07:04 PM
The 9 Store
I assumed the OP was just talking about front brakes/calipers/struts. I wouldn’t use S calipers f&r. It’s not the right ratio.
Old 01-24-2023, 07:38 PM
