Oil in intake tract - how bad?
Well, I know that oil in the intake tract is bad - just trying to determine how bad.
I pulled the intercooler and there was oil sitting in the lip on the up-pipe. I flooded the engine a bit getting my CIS set up, which I'm sure made the oil a little thinner. The turbo is a new K27-7200 and I have a catch can and factory scavenge pump (which I think is working fine based on the small leak at the intake side of the scavenge). Do we think the turbo needs a reseal, or is it just a result of the thinned out oil? I should have also mentioned I haven't even driven the car yet - just idled in my garage for probably less than 10 minutes total. |
Oil can drain/siphon down in to the turbo when it is sitting. I would run it first and see what you find. You may need an anti drain valve (TK- easy fix).
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
you didnt thin the oil enough to make a difference with 15 qrts of oil.
if you put enough fuel in there you stand a better chance of hydro lock. did you over fill it. i would run it some more.
