dewolf's Avatar
Shift Knob Removal
Can anyone help with shift knob removal? I have tried to rotate it to remove it but to no avail. How do they come off?
Scott
Old 04-15-2007, 09:28 PM
sudo apt-get purge 930
equality72521's Avatar
It slides off. There is a compression sleeve inside the knob and sometimes it's tough to break free. Some have used a piece of wood as a drift and tapped the bottom of the knob until it slides off.
--clutch-monkey
Old 04-16-2007, 04:05 AM
wcc wcc is offline
wcc's Avatar
What year is your car?
If it's '86 and older it has a crush sleeve that is held on by pressure:
If it's '87-'89 then there is a screw under the cap that holds it on:
Bill
997.2
Old 04-16-2007, 04:08 AM
dewolf's Avatar
Cool, thanks guy's. So it's a couple of good 'ole love taps with a mallet.
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 04-16-2007, 04:22 AM
930gt-40r's Avatar
I had the same problem and then lost motivation to take it off, so I left it alone. I will try again after being armed with this info
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 04-16-2007, 06:41 AM
Driver
Noah930's Avatar
I know this is an old thread, but can anyone confirm if wcc's image is correct? I have an '87, and a newly gifted 917-inspired shift knob I'd like to swap into my car. Just lefty-loosey the OEM knob and it should come off? And I can remove the knob without having to remove the leather shifter boot?
I took a look at this thread, too: https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/596430-shifter-inspection-removal-instructions.html
Two guys (Paul and oilonly) both had '87s, but one knob was threaded on, and the other was a pry-the-cap-off-and-remove-a-screw type. Any way to tell which is which before I destroy anything?
1990 Black 964 C2 Targa
Old 03-23-2019, 03:43 PM
M5guy's Avatar
My 86 has the screw on type with a locknut. Which allows for easy orientation.
Now does anyone know how to get the e brake handle off? PO put on an aluminum one for obvious horsepower gains but I want to replace it with OEM black.
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette.
Old 03-23-2019, 04:11 PM
Mike80911's Avatar
Some of those aftermarket brake handles have an allen key set screw underneath if not it should just pull off
89 930 Cab Black
11 Cayenne
Old 03-23-2019, 06:44 PM
What size is the shift knob bolt? Can't find it on PP.
2017 Macan GTS
2016 GT4
2012 R8
1987 911 Carrera
1956 Speedster
Old 05-02-2019, 02:29 PM
Scratch that - M8 X 1.25 x 40 Hex head bolt did the trick.
2017 Macan GTS
2016 GT4
2012 R8
1987 911 Carrera
1956 Speedster
Old 05-03-2019, 12:58 PM
Driver
Noah930's Avatar
OK, so I answered my own question from above. Different years seem to have different methods of attaching the OEM shift knob to the lever. FWIW, for my '87 (built in January of 1987), it was the allen screw under the cap method. No crush sleeve. Pried off the cap (there are 3 prongs, with one at the 12 o'clock position), and then removed the 6 mm allen screw bolt.
Old 05-27-2019, 11:12 AM
I have vintage shift knob with a 15mmx1.5 female thread
I want to install it on 1971 911T shift stick
Any possibility ?
Old 10-15-2022, 08:16 PM
