Replacing clutch - oil behind pilot bearing?
Hi all,
Changing the clutch on my '81 930 due to shudder. Removed the flywheel and pilot bearing. Crankshaft seal seems to have been replaced not too long ago. However, behind the pilot bearing it is 'oily'. Should it be this oily? Can't find it on the forum. ![]()
----------------------------------- 1971 911 T Targa 1980 930 Turbo 2017 991.2 4S Targa 2023 Cayenne |
probably grease, the pilot bearing should be greased, some types will break down looking like oily residue.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
looks like grease
if the seal was leaking you would have oil around the seal. check the case seam below the seal. make sure that is sealant and not oil
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Thanks. Case seam is dry, no oil... Flywheel is being resurfaced and new parts are on their way. Next week: putting things back together!
Always a good idea to replace the pilot bearing each time you do the clutch. Good preventative maintenance.
