mark houghton's Avatar
Key light hack
Since we're a pretty DIY heavy group...or used to be...here's a hack to convert your lighted key to new-world LED's. 35 year old technology gone bye bye.
Use a CR1632 battery, a 5mm green or blue LED, a spacer beneath the push button to take up some slack since the stock 1.5v battery is twice as tall, expand the battery housing diameter with a Dremel about 0.8mm, do a simple soldering...and done.
https://youtu.be/PoJgiX54E7M
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-30-2022, 01:23 PM
Bucketlist's Avatar
Thanks Mark for the post. Being a guy that needs pictures to show me the way I did a search and came up with this old Pelican post. I haven't tried either yet but its on my list.
Lighted Key Head Conversion to LED
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 10-31-2022, 03:48 AM
Cool, I never thought to look if someone else has done this. My process was a bit less involved and I used a 3.2v battery instead of the 2.5v he used, mostly because I needed a higher voltage to drive my LED to full brightness. The white LED I had on hand requires 3.2v minimum to barely drive it. Would have to search around to find one with lower forward voltage.
Personally I like the green, a bit easier on the eyes and plenty bright to light up a small room.
I should have taken pictures of the process but oce you get into it, it's pretty self explanatory..
Old 10-31-2022, 06:45 AM
Did this mod around when the article was written. With super clear/bright LEDs available at the time, output was so bright you'd get spots in your eyes if you looked directly at it in daylight.
'77 S with '78 930 power and a few other things.
Old 10-31-2022, 12:50 PM
Alan L's Avatar
U guys are soooooooo soft.
Use a maglite
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-01-2022, 12:53 AM
Use a maglite
Alan
Well there ya go! Just hang a mag light from your key chain.
I've lived without a lighted key for years and years; now that I have one I'll probably never use it. Just gave me a little project on an otherwise boring day.
Old 11-01-2022, 07:25 AM
